Pattern along a compound curve.
Re: Pattern along a compound curve.
I'm at the step where I am trying to pattern holes along the curve. The problem I am having right now is that I am unsure of how to get the holes to be tangent to the surface of the body. This is what I have attempted so far:
. The annotated image below is what I am trying to achieve: . I want a set of 12 holes evenly spaced at the centre of the arc. I am also unsure of how I can specify where the first instance of my pattern should occur along the curve so that it doesn't start at the very beginning. Thanks for the help.-
@keshmaster81
It was easier to start from scratch. Too much unnecessary clutter in your file.
Used a revolution not a sweep to make the base object.
Adjust the point in Sketch to locate the line of centers.
Sketch002 is a construction line to attach the pocketing Sketch001 to.
Used polar patterns to replicate the holes. You adjust the number and angle.
- hydro.FCStd
- (417.92 KiB) Downloaded 14 times
- mytyreisflat_SHALM.FCStd
- (273.14 KiB) Downloaded 12 times
- Capture d’écran 2023-05-16 181415.jpg (49.89 KiB) Viewed 947 times
Wow thank you so much! I wish I had thought of using a revolution instead of a sweep. It's so much cleaner and well designed.edwilliams16 wrote: ↑Mon May 15, 2023 8:38 pm @keshmaster81
challenge: do this pattern along a spline. (the hole is on the 45° radial)
- Capture.JPG (27.06 KiB) Viewed 858 times
@Vincent B
Your solution had to be less convoluted than mine.
- holesonbsplinehalfpipe.FCStd
- (324.85 KiB) Downloaded 16 times
This is a little cleaner. Attached a vertex to the hole curve, then the sketch can be attached tangent to the surface at the vertex. As before, use a Lattice2 paraseries looping on the Vertex's map path. Had to discretize and interpolate the sweep path so as to make map path linear with distance to get equally spaced holes.
I suspect I could use Draft|Path Array instead of Lattice2, but couldn't figure out how to get the circle sketch tangent to the surface.
- holesonbsplinehalfpipe2.FCStd
- (257.05 KiB) Downloaded 13 times
Hi Vincent B, Greetings to the Community!
...here is my flow for your "snake" with holes at 45°
- holey_snake_domad.FCStd
- (265.91 KiB) Downloaded 18 times
- holey _snake_domad.png (137.6 KiB) Viewed 662 times
