[Release Note for FC_0.21] - Updates for Arch, BIM & Draft
paullee
Post by paullee »
In view of the coming 0.21 release soon, wondering if the current release notes has included most of the new features, bug fixes, and if BIM WB should be included? Hope there are peoples who have resources working on this.
https://wiki.freecad.org/Release_notes_ ... _Workbench
@Roy_043, @yorik and others should had made lots of PR, do you have a gap to have a look? :)
markko martin
Re: [Release Note for FC_0.21] - Updates for Arch, BIM & Draft
Post by markko martin »
I didn't know that the terrain could also be a solid.
I was just thinking mesh.
I think there is some mistake because link open this page: [Arch] fix Arch_Stairs recompute issue #8444
( The Terrain of an Arch Site can now also be a solid. Pull request #8444 )
Loris
Roy_043
Post by Roy_043 »
I have tried to keep the Wiki up to date, but I'll check anyway.
markko martin wrote: Sat May 13, 2023 8:56 am The Terrain of an Arch Site can now also be a solid. Pull request #8444
Thanks. Copy-paste error. I'll fix that.
paullee
Post by paullee »
markko martin
Roy_043 wrote: Sat May 13, 2023 10:36 am Copy-paste error. I'll fix that.
Thank you Roy :)
Loris
Roy_043
Post by Roy_043 »
I have added 3 PRs that I felt were important enough.
Note that some bug fixes were backported, these are not mentioned in either the release notes of V0.20 or V0.21.
viewtopic.php?t=69437
paullee
Post by paullee »
viewtopic.php?t=17498&start=180#p682075
Some updates mentioned by Yorik -
" FreeCAD fixes: These are the other fixes I’ve been working on this week in FreeCAD:
Draft: Indicate which DXF pref option is for legacy importer/exporter only by yorikvanhavre · Pull Request #9545 · FreeCAD/FreeCAD · GitHub
Start: Fixed loading from custom folder by yorikvanhavre · Pull Request #9537 · FreeCAD/FreeCAD · GitHub
Draft: Skip SVG import DPI dialog if a unit is specified in the file by yorikvanhavre · Pull Request #9533 · FreeCAD/FreeCAD · GitHub
Draft: Better svg linestyle settings - fixes #6733 by yorikvanhavre · Pull Request #9530 · FreeCAD/FreeCAD · GitHub
Draft: Support group styles in SVG import - fixes #6900 by yorikvanhavre · Pull Request #9522 · FreeCAD/FreeCAD · GitHub
Arch: Removed html from tooltips by yorikvanhavre · Pull Request #9515 · FreeCAD/FreeCAD · GitHub
Draft: Added dim overshoot parameters to Style task dialog by yorikvanhavre · Pull Request #9514 · FreeCAD/FreeCAD · GitHub
yorik
Post by yorik »
These are mostly bugfixes... Not sure if that's worth adding to the release notes?
