OS: Pop!_OS 22.04 LTS (pop:GNOME/pop)
Version: 0.21.0.33127 (Git)
Build type: Unknown
Hash: a669e4423a32174eef1a65c65f718fb55ecf042f
Python 3.10.6, Qt 5.15.3, Coin 4.0.0, Vtk 7.1.1, OCC 7.5.1
* fasteners 0.4.56
* kicadStepUpMod.backup1663010049.9382765
* Render 2023.2.3
* Help 1.0.3
* A2plus 0.4.60k
* fcgear 1.0.0
* lattice2 1.0.0
* kicadStepUpMod 10.18.8
09:27:36
09:27:36 Material card chosen:
/home/bruce/Apps/freecad-build/share/Mod/Material/StandardMaterial/Aluminum-2024T6.FCMat
09:27:36
09:30:55
09:30:55 Material card chosen:
09:30:55
09:31:03 Material card chosen:
/home/bruce/Apps/freecad-build/share/Mod/Material/StandardMaterial/Aluminum-7075.FCMat
09:31:03 ThermalConductivity not found in AW-7075
09:31:03 SpecificHeat not found in AW-7075
09:31:03
09:31:08 Zero ThermalConductivity value. This parameter is not saved in the material data.
09:31:08 Zero SpecificHeat value. This parameter is not saved in the material data.
09:32:03 ElementDimension: 3
09:32:03 Group meshing for analysis is set to true in FEM General Preferences. Are you really sure about this? You could run into trouble!
09:32:03 Problem: For the geometry of the following shape was no Shape found: <Face object at 0x564992aad820>
09:32:03 ConstraintPressure001
09:32:03 [(<PartDesign::LinearPattern>, ('Face37',))]
09:32:03 LinearPattern
09:32:03 The reference Shape is not a child nor it is the shape the mesh is made of. : <Face object at 0x564992aad820>
09:32:03 Body--> Name of the Feature we where searching in.
09:32:03 LinearPattern --> Name of the parent Feature of reference Shape (Use the same as in the line before and you will have less trouble :-) !!!!!!).
09:32:03 Problem: For the geometry of the following shape was no Shape found: <Face object at 0x56498e7c40c0>
09:32:03 [(<PartDesign::LinearPattern>, ('Face39', 'Face38'))]
09:32:03 The reference Shape is not a child nor it is the shape the mesh is made of. : <Face object at 0x56498e7c40c0>
09:32:03 Problem: For the geometry of the following shape was no Shape found: <Face object at 0x564994434390>
09:32:03 The reference Shape is not a child nor it is the shape the mesh is made of. : <Face object at 0x564994434390>
09:32:03 Problem: For the geometry of the following shape was no Shape found: <Face object at 0x5649928fc7a0>
09:32:03 ConstraintFixed
09:32:03 [(<PartDesign::LinearPattern>, ('Face8',))]
09:32:03 The reference Shape is not a child nor it is the shape the mesh is made of. : <Face object at 0x5649928fc7a0>
09:32:03 Empty reference: MaterialSolid
09:32:03 One material with no reference shapes. No need to make a group for materials.
09:32:03 Error: The shapes for the mesh group for the reference shapes of analysis member: ConstraintPressure001 could not be found!
09:32:03 Error: The shapes for the mesh group for the reference shapes of analysis member: ConstraintPressure could not be found!
09:32:03 Error: The shapes for the mesh group for the reference shapes of analysis member: ConstraintFixed could not be found!
09:32:03 /tmp/fcfem_wj7hb__s/Body_Geometry.brep
09:32:03 /tmp/fcfem_wj7hb__s/Body_Mesh.unv
09:32:03 /tmp/fcfem_wj7hb__s/shape2mesh.geo
09:32:03 /home/bruce/Apps/gmsh/gmsh-4.11.1-Linux64/bin/gmsh
09:32:03 Unexpected error when creating mesh: list index out of range
09:32:03 Gmsh had warnings:
09:32:03 list index out of range
09:32:09 Fem::FemMeshObjectPython: Link(s) to object(s) 'Body' go out of the allowed scope 'FEMMeshGmsh'. Instead, the linked object(s) reside within 'Part'.
09:33:15 ElementDimension: 3
09:33:15 Group meshing for analysis is set to true in FEM General Preferences. Are you really sure about this? You could run into trouble!
09:33:15 Problem: For the geometry of the following shape was no Shape found: <Face object at 0x5649918ff260>
09:33:15 ConstraintPressure001
09:33:15 [(<PartDesign::LinearPattern>, ('Face37',))]
09:33:15 LinearPattern
09:33:15 The reference Shape is not a child nor it is the shape the mesh is made of. : <Face object at 0x5649918ff260>
09:33:15 Body--> Name of the Feature we where searching in.
09:33:15 LinearPattern --> Name of the parent Feature of reference Shape (Use the same as in the line before and you will have less trouble :-) !!!!!!).
09:33:15 Problem: For the geometry of the following shape was no Shape found: <Face object at 0x5649944add70>
09:33:15 [(<PartDesign::LinearPattern>, ('Face39', 'Face38'))]
09:33:15 The reference Shape is not a child nor it is the shape the mesh is made of. : <Face object at 0x5649944add70>
09:33:15 Problem: For the geometry of the following shape was no Shape found: <Face object at 0x5649944b1430>
09:33:15 The reference Shape is not a child nor it is the shape the mesh is made of. : <Face object at 0x5649944b1430>
09:33:15 Problem: For the geometry of the following shape was no Shape found: <Face object at 0x5649944adb10>
09:33:15 ConstraintFixed
09:33:15 [(<PartDesign::LinearPattern>, ('Face8',))]
09:33:15 The reference Shape is not a child nor it is the shape the mesh is made of. : <Face object at 0x5649944adb10>
09:33:15 Empty reference: MaterialSolid
09:33:15 One material with no reference shapes. No need to make a group for materials.
09:33:15 Error: The shapes for the mesh group for the reference shapes of analysis member: ConstraintPressure001 could not be found!
09:33:15 Error: The shapes for the mesh group for the reference shapes of analysis member: ConstraintPressure could not be found!
09:33:15 Error: The shapes for the mesh group for the reference shapes of analysis member: ConstraintFixed could not be found!
09:33:15 /tmp/fcfem_8ct05njq/Body_Geometry.brep
09:33:15 /tmp/fcfem_8ct05njq/Body_Mesh.unv
09:33:15 /tmp/fcfem_8ct05njq/shape2mesh.geo
09:33:15 /home/bruce/Apps/gmsh/gmsh-4.11.1-Linux64/bin/gmsh
09:33:15 Unexpected error when creating mesh: list index out of range
09:33:15 Gmsh had warnings:
09:33:15 list index out of range
Python 3.10.6 (main, Mar 10 2023, 10:55:28) [GCC 11.3.0] on linux
Type 'help', 'copyright', 'credits' or 'license' for more information.
>>> # Gui.runCommand('Std_Workbench',11)
>>> # Gui.runCommand('Std_ViewStatusBar',1)
>>> # Gui.runCommand('Std_Workbench',18)
>>> import PartDesignGui
>>> # Gui.runCommand('Std_Workbench',19)
>>> # Gui.runCommand('Std_Workbench',20)
>>> # Gui.runCommand('Std_Workbench',22)
>>> # MRU="0"
>>> # with open('/home/bruce/Apps/freecad-build/share/Mod/Start/StartPage/LoadMRU.py') as file:
>>> # exec(file.read())
>>> FreeCAD.openDocument('/home/bruce/Documents/freecad/PressureTube/mjp_L2.FCStd')
>>> # App.setActiveDocument("mjp_L2")
>>> # App.ActiveDocument=App.getDocument("mjp_L2")
>>> # Gui.ActiveDocument=Gui.getDocument("mjp_L2")
>>> # Gui.Selection.addSelection('mjp_L2','MaterialSolid')
>>> # App.getDocument('mjp_L2').getObject('MaterialSolid').ViewObject.doubleClicked()
>>> # Gui.Selection.addSelection('mjp_L2','Analysis')
>>> # Gui.activateWorkbench('FemWorkbench')
>>> # import FemGui
>>> # FemGui.setActiveAnalysis(App.activeDocument().Analysis)
>>> # Gui.Selection.clearSelection()
>>> ### Begin command Std_ViewRight
>>> # Gui.activeDocument().activeView().viewRight()
>>> ### End command Std_ViewRight
>>> # Gui.Selection.addSelection('mjp_L2','Part','Body.LinearPattern.Face1',16.5393,-55.443,-7.66673)
>>> # Gui.Selection.addSelection('mjp_L2','Part','Body.LinearPattern.',16.5265,-92.9607,-7.67741)
>>> # Gui.Selection.addSelection('mjp_L2','Part','Body.Groove003.')
>>> # Gui.ActiveDocument.setEdit(App.getDocument('mjp_L2').getObject('Groove003'), 0)
>>> # Gui.activateWorkbench('PartDesignWorkbench')
>>> App.getDocument('mjp_L2').recompute()
>>> # Gui.getDocument('mjp_L2').resetEdit()
>>> # Gui.Selection.addSelection('mjp_L2','FEMMeshGmsh')
>>> # Gui.runCommand('Std_ToggleVisibility',0)
>>> # App.getDocument('mjp_L2').getObject('FEMMeshGmsh').ViewObject.doubleClicked()
>>> # Gui.runCommand('Std_About',0)
; Aluminum-2024T6
; Uwe Stöhr
; information about the content of such cards can be found on the wiki:
; https://www.freecad.org/wiki/Material
; file created by BDL42 05062023
[General]
Name = Aluminum Generic
Father = Metal
KindOfMaterial = Aluminium
[Mechanical]
Density = 2780 kg/m^3
PoissonRatio = 0.33
ShearModulus = 27.0 GPa
UltimateTensileStrength = 427 MPa
YieldStrength = 305 MPa
YoungsModulus = 72400 MPa
[Thermal]
SpecificHeat = 875.0 J/kg/K
ThermalConductivity = 151.0 W/m/K
ThermalExpansionCoefficient = 23.2 µm/m/K
[Electromagnetic]
ElectricalConductivity = 370370.4 S/m
RelativePermeability = 1.0
; Aluminum-7075
; (c) 2014 M. Münch - GNU Lesser General Public License (LGPL)
[General]
Name = AW-7075
NameDE = AlZnMgCu1,5
Father = Metal
KindOfMaterialDE = Aluminium
MaterialNumber = 3.4365
Norm = DIN 1725-1
[Mechanical]
Density = 2810 kg/m^3
PoissonRatio = 0.33
ShearModulus = 27000 MPa
UltimateStrain = 10
UltimateTensileStrength = 572 MPa
YieldStrength = 505 MPa
YoungsModulus = 71700 MPa
[Thermal]
ThermalExpansionCoefficient = 0.0000234 m/m/K
~/Apps/freecad-build/bin$ ./FreeCAD
FreeCAD 0.21.0, Libs: 0.21.0R33127 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2023
connect failed: No such file or directory
ElementDimension: 3
LinearPattern
ConstraintPressure
LinearPattern
ConstraintPressure
LinearPattern
ConstraintFixed
LinearPattern
Gmsh had warnings:
ElementDimension: 3
LinearPattern
ConstraintPressure
LinearPattern
ConstraintPressure
LinearPattern
ConstraintFixed
LinearPattern
Gmsh had warnings:
