Path: Toolpath for operations smaller than tool width.
I am new to FreeCAD, and CNC/CAM so please bare with me.
I wanted to build some simple hold downs for the CNC machine, and am struggling a bit to create a toolpath that works optimally for this simple part. The main problem I am encountering is trying to profile and edge that is less than the width of the tool bit. It's the outside edge so there should be no problem to remove the outside of the stock, and only cut in 3mm with a 6.25mm bit.
The only way I have found so far to create this toolpath with a 6.35mm bit is to do a lap around the entire piece with a profile for every 3mm step shown on the right. This adds a fair bit of wasted time when it could just be profiling the right edge, but FreeCAD seems to refuse to make a profile or pocket toolpath for a surface that is less than the width of the bit.
Am I missing something obvious?
FWIW I am using FreeCAD 0.20.2 on Manjaro Linux.
- stair clamp.FCStd
- (158.22 KiB) Downloaded 28 times
Re: Path: Toolpath for operations smaller than tool width.
Yes probably:
http://forum.freecadweb.org/viewtopic.php?f=3&t=2264
about how to post a correct FreeCAD (FC for short) info.
Sadly there are around many version so it is not clear if you are using as example an AppImage or a distribution compiled version.
This could be the cause as example if someone is trying your file with the AppImage, he could not confirm the behaviour or the other way round.
And this not tell as example against what libraries FC is compiled.
Thank you for your response, however detailed specifics of FC version should not be incredibly important here, I'm not reporting a bug, just trying to understand basic functionality of toolpaths in 0.20.2.
I think I can simplify my question a bit. How does one create a profile or pocket toolpath that cuts into the stock from the outside edge, for a cut that is smaller than the tool bit diameter?
OS: Manjaro Linux (KDE/plasma)
Version: 0.20.2.29603 (Git)
Branch: makepkg
Python 3.10.9, Qt 5.15.8, Coin 4.0.1, Vtk 9.2.6, OCC 7.6.3
Locale: English/Canada (en_CA)
* A2plus 0.4.60k
Moved to Path forum.
You can use the PathPocket with extensions. Alas, the predefined half of the tool diameter doesn't work. I had to increase it a bit, whhich creates a double tool path. Not sure if this is a bug.
I can upload the 0.21 version of the file (incompatible with 0.20).A Sketcher Lecture with in-depth information is available in English, auf Deutsch, en français, en español.
Hi @chrisb, thanks for your reply. I did try with extensions, but unsuccessfully. I have now updated to latest 0.21-weekly, and trying again, I see that I can create the toolpath with extension, I didn't realize it needs a negative number entered here for what I want.
My solution for this part seems a bit hokey. I added the extension to create the toolpath, then offset the toolpath position to move it to where I wanted. Perhaps you have a better solution, please post the file you mentioned, I am interested to look at it.
Version: 0.21.0.33110 (Git) AppImage
Hash: 18e40941ceb36c52701a7c74ea26043ef3385701
Python 3.11.3, Qt 5.15.8, Coin 4.0.0, Vtk 9.2.2, OCC 7.7.1
* A2plus 0.4.60k
Here is the file. You can see the double line, perhaps an additional boundary dressup can suppress it.
- stair clamp_cb.FCStd
- (114.73 KiB) Downloaded 23 times
I played with this file for a while, using a very recent version 0.21. (Good move to update!)
I was able to use the single-edge function of the Profile operation to pattern the steps with minimal extra moves.
The only problem is that each step needs to be set up exactly for the start height and the finish height.
If this is a repetitive job then it is worth setting up. If it is a one-timer I would just go with the full orbit profile and get on with life.
Gene
Gene
EDIT: posted as Gene also posted. Same solution.reet wrote: ↑Sun May 07, 2023 6:09 pm Hello,
I was able to do the job by using the Profile Op, selecting the top edge of a step, and setting depth and step down to suit
There is no lead in but could be added.
Worked in both Ver 0.20 and Ver 0.21
OS: Ubuntu 20.04.6 LTS (ubuntu:GNOME/ubuntu)
Version: 0.20.28993 (Git) AppImage
Branch: (HEAD detached at 6d92e53)
Hash: 6d92e532bcc31c99a0ab4c153ff00b6414b8f527
Python 3.9.13, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
* fcgear 1.0.0
* Curves 0.4.4
* Lithophane
* CurvedShapes 1.0.3
Version: 0.21.0.33040 (Git) AppImage
Hash: 1e830a8800156097ccb3ef6124dced30d4002e76
Python 3.11.3, Qt 5.15.8, Coin 4.0.0, Vtk 9.2.2, OCC 7.7.0
* fcgear 1.0.0
* Curves 0.4.4
* Lithophane
- mod_stair clamp.FCStd
- (154.4 KiB) Downloaded 24 times
Thank you. I see, you are referring to a different option that what I was looking at. I was looking at the "pass extension".
It does only need one pass, but even 2 passes is still better than doing a lap around the entire part like I was doing. You do have the extension formula as "OpToolDiameter * 0.55", however the bit is 6.35mm, and the step is 3mm, so the extension would be a very specific "OpToolDiameter * 0.527559055118", however it doesn't seem to matter how close you get the math, it wants to do 2 passes, I think it's inherent to the pocket operation.
For this particular part, I could use a slot operation with a X axis offset in the placement, but understandably that may not work for every situation.
Thanks again for your help.
