Hello all,
As many of you know, there is a topological naming problem. Here is the solution to the problem: https://wiki.freecad.org/Topological_naming_problem
However, this approach does not work on my CAD design that has screw holes or so on.
Have you found a better solution to this problem?
Sincerely...
Topological naming problem
- topological_naming.jpeg (19.89 KiB) Viewed 7185 times
Re: Topological naming problem
That's not the solution, it is a way to mitigate the problems occuring from it.erencanbulut wrote: ↑Thu May 04, 2023 10:43 am there is a topological naming problem. Here is the solution to the problem: https://wiki.freecad.org/Topological_naming_problem
With the information you give, there is nothing more to say than that: fix your error and continue. Honestly, without the file or at least an extremely detailed description of the problem, there is hardly more help possible.
