FreeCad CfdOF "Not Responding"
Moderator: oliveroxtoby
markinca
Post by markinca »
Version: 0.20.2.29603 (Git)
Branch: releases/FreeCAD-0-20
  * CfdOF 1.22.5
  * Help 1.0.3
WIndows 11
I have a very long CfdOF simulation running and have sleep mode turned off. If I leave the computer and after 30 min or so, come back, FreeCad no longer responds and in the title bar it says "Not Responding". However, I can see in Task Manager that FreeCad has CPU time and so do the InterFoam processes. It seems like just the FreeCad GUI is frozen but everything else is continuing on.
This has happened both times that I have tried to run this sim.
Is this a FreeCad issue or a CfdOF issue?
Raedchen_im_System
Re: FreeCad CfdOF "Not Responding"
Post by Raedchen_im_System »
Hello markinca,
if you have a question like this, you should upload your FreeCad model so that others - here in particular Oliver - can reproduce your problem. You should upload the model without a mesh, because the mesh takes up a lot of storage space.
In some models, I had the same issue. I am very sure that this is not an issue of FreeCad or CfdOf, but of OpenFoam for Windows: When you look in the log-file of the solver (in your case: log.interfoam), you will see that this file is not updated either. The log files are in the "case"-directory, you can access this directory, if you click "edit" in the solver-menu of CfdOf.
This is not a large issue, you can just wait until OpenFoam finishes. You can see either in the log file or in the task manager that OpenFoam has ended. In most cases, FreeCad then "comes back to live" again. If not, you can just close FreeCad via Taskmanager and restart again. You can review the results by clicking "paraview" in the solver menu.
Version: 0.20.1.29410 (Git)
  * A2plus
  * Assembly4 0.12.5
  * CfdOF 1.21.4
  * fasteners
  * FCGear
  * Plot
markinca
Post by markinca »
Thanks for the reply!
I believe you are correct. I took a look at the log file and it was last written at about 2pm yesterday slightly before I noticed FreeCAD was frozen. I also looked at the openfoam time step folders/files and those were updated last evening at around 8pm so the simulation has technically "finished" because the last time step was written but Interfoam is still running and FreeCAD is still frozen.
I decided to terminate FreeCAD and shortly there after, Interfoam stopped running too without my intervention. This seems like it could be an interface issue between CfdOF and Openfoam.
I may try a different simulation and see if the same thing happens.
Spa_Jet_TR.FCStd
(59.32 KiB) Downloaded 47 times
Venturi 3.step
(27.83 KiB) Downloaded 45 times
markinca
Post by markinca »
UPDATE
Tried a different simulation and FreeCAD froze in much shorter time (< 10min).
If I do any work on the PC while the simulation is running, then everything runs ok. It seems to be only when there are no other inputs to the PC.
Convection.FCStd
(76.47 KiB) Downloaded 49 times
oliveroxtoby
Post by oliveroxtoby »
markinca wrote: Fri May 05, 2023 5:12 pm UPDATE
Sadly I haven't been able to reproduce this issue on my Windows system, but I'll see if I can think of anything...
markinca
Post by markinca »
I find that it will only hang when you leave the computer to process without any user input for some time (~30min). If I am using the computer at the same time as the simulation, it seems to continue without issue. My first thought is it has something to due with the Windows idle timer but I wasn't sure if FreeCAD uses that or not.
But again, the computer is configured to "Never" go into sleep. I also tried with and without hard drives turning off and that had no effect either but probably because I have an SSD. One thing I have not tried yet is to disable the display blanking. That might be next when I get some time but I did have a freeze before the screens went blank so I kind of ruled that out too.
Thanks
markinca
Re: FreeCad CfdOF "Not Responding" [SOLVED]
Post by markinca »
I think I may have found what was causing FreeCad to freeze.
I noticed that the volume of messages to the "Report View" was quite large and was coming across very quickly. I found a setting in General > Output Window > "Redirect internal Python output to report view" and I unselected it. No more freezes.
I think the reason that it was freezing on my machine but not others may have to do with processing power and the rate at which the messages were delivered to the "Report view". The processor in my machine is an AMD 5900HX 8 Core/16 Threads and I was using all cores/threads for parallel processing. I think the simulation processing speed was overwhelming the buffer for the report view window. This is probably why the memory for FreeCAD kept growing as it was attempting to keep all of these messages in active memory.
I have seen similar behavior with Excel VBA and the Immediate window. If you write to much data to that window, Excel will freeze.
oliveroxtoby
markinca wrote: Fri May 12, 2023 2:01 pm I noticed that the volume of messages to the "Report View" was quite large and was coming across very quickly. I found a setting in General > Output Window > "Redirect internal Python output to report view" and I unselected it. No more freezes.
Fantastic, thanks so much for figuring that out. I'll try to put in a fix shortly.
markinca
Post by markinca »
I think I found another solution.
Instead of unchecking "Redirect internal Python output to report view"
I checked "Use software OpenGL" in the Display settings and that too prevented the freezing.
software opengl severely hurts the performance of the 3d view, I do not recommend using it if you don't need it.
