[Announcement] GPT4FreeCAD Plug-In
thschrader
Re: [Announcement] GPT4FreeCAD Plug-In
Post by thschrader »
revhappy wrote: Wed May 03, 2023 4:05 am This is something I have imagined for a while. Imagine natural language prompts to create a model.
Looking forward to your feedback and suggestions!
Sounds interesting.
Some questions from an old dog:
1. Is it possible to feed the AI (any AI?) with old pdf or hand drawings and get a CAD-model, or at least a 2D dwg-file?
We often get drafts from other engineers in pdf format, we must redraw the stuff manually in CAD.
2. Is it possible to run the AI on my local machine?
One of our customers is the governement, we are not allowed to share files on servers.
Regards Thomas
example: EDIT: deleted customer drawing due to request
bleber
Post by bleber »
I think that there are AI open source that you can run locally, other thing is training the AI to make drawings from scanned images.
@revhappy did you see viewtopic.php?p=681636#p681636 ?
MisterMaker
Post by MisterMaker »
I'm out of a job if this ever gonna take off. :shock:
Well at least I'd have more time to spend om Freecad and other hobbies.
heron
Post by heron »
revhappy wrote: Wed May 03, 2023 4:05 am You can find the GPT4FreeCAD workbench on GitHub: https://github.com/revhappy/GPT4FreeCAD
Hello @revhappy and many thanks for this plugin.
I'm trying to play around with chatgpt in FreeCAD and can't get it to work. I have an Open AI API key for ChatGPT 3.5 which is my free option on openai.com here.
Is it compatible with ChatGPT 3.5?
FreeCAD 0.20.2 with the GPT4FreeCAD folder in the Mod folder crashes before starting.
FreeCAD 0.21 runs the macro fine but gives me errors when an input is executed.
If you are interested, I can give you the crash log file, or my full about Freecad info.
Freakcad_User
Post by Freakcad_User »
This is definitely interesting. AI assisted design is definitely coming. Like many, I have mixed feelings about how much AI can and will take over for humans.
Anyone tried Chat GPT to write code for FreeCAD (or other applications)? What I'm gathering is that to be successful using it to write code, you basically need to be good at writing code yourself, which I am not. This is because you need to:
1. Be able to verify and fix the code when needed, and also realize when it's spitting out a bunch of crap.
2. Be able to give it accurate and clear instructions, which is somewhat similar to instructing another human to do a new task. Garbage in, garbage out.
It also seems to be a lot more successful in creating smaller elements of an application. The larger and complex the task, the more it falls down.
Here's an article I just read about this topic if anyone is interested:
https://www.zdnet.com/article/how-to-us ... rite-code/
Todd M.
thschrader
thschrader wrote: Fri May 12, 2023 12:23 pm
Sounds interesting.
Regards Thomas
EDIT: deleted due to customer request
example:
ebrahim raeyat
Post by ebrahim raeyat »
Automation and AI in BricsCAD BIM, It is interesting:
@yorik
https://issuu.com/augi/docs/aw202307hr/26
Imagine
Post by Imagine »
Great Idea, Relatively new to coding & what I do learn is forgotten between intervals, every now & again I come across something that peaks my interest & 9/10 wish I was using Linux UI, How to compile github repos for Windows?
I have tried the drag & drop into both Mod Files, And perhaps the API system open AI implemented in 2023 is outdated? Considering it's everywhere in 2024. Hmmm it's not in FC-Windows! It needs to be (IN THE NAME OF PROGRESS).
