Windows 11 Installation
I have installed FreeCAD (0.20.2), CfdOF (1.22.4), Openfoam (v2206), Paraview (5.10.1), cfMesh & HiSA all in administrator mode. Also, when installing Openfoam, I have made sure to select the MPI installation. However, when I run the dependency check, I get this error:
"MPI is not installed. Parallel execution will not be possible."
However, when I look in "Programs and Features", I see that "Microsoft MPI (10.1.12498.18)" is installed. So what is going on here?
Thanks
[EDIT] - After running a simulation, there appears to be multiple processor folders in the case folder so it looks like it is using multiple processors but the "Check Dependency" reports differently.
CfdOF Check Dependency Error
Moderator: oliveroxtoby
- oliveroxtoby
Re: CfdOF Check Dependency Error
Sorry, just an error with the dependency checker on Windows. Should be fixed now. Thanks for reporting.markinca wrote: ↑Sun Apr 30, 2023 2:54 pm Windows 11 Installation
Thanks
Thanks!
