There will be a version 0.21 release...
Roy_043
Post by Roy_043 »
In case you have missed it, there will be a version 0.21 release:
viewtopic.php?t=77989
This will have some impact on the Wiki. Everything marked as a v1.0 feature will actually be a v0.21 feature.
The new version of the Wiki software won't allow the renaming of the Release_notes_1.0 page as more than 500 pages (mainly translation units) are involved. This apparently has to be done by an admin with the help of a maintenance script now.
For the Release_notes_1.0 page it is probably easier to create a new page, even though this will require some extra work for translators. But when translating the new page, already translated sections will of course be found in the database. So I am going to go ahead and create this new page.
FBXL5
Re: There will be a version 0.21 release...
Post by FBXL5 »
Roy_043 wrote: Sat Apr 29, 2023 4:36 pm But when translating the new page, already translated sections will of course be found in the database.
The german translation of the release notes 1.0 was about 98% complete, but only about 86% could be recovered from the data base. :(
Will the remaining 12% be available in the next couple of days/weeks? Especially the FEM sections were a pain to translate with the little knowledge I have, even though it improved over the translation process.
Roy_043
Post by Roy_043 »
This should (hopefully) still contain the most recent German translation:
https://wiki.freecad.org/index.php?titl ... id=1256477
FBXL5
Post by FBXL5 »
Thanks for the link.
Edit: That helped a lot, the page is at 99% now.
kaktus
Post by kaktus »
The translation memory contains only blocks up to a certain number of strings.
Roy can I ask for a link to the Polish hisrotic version?
Roy_043
Post by Roy_043 »
kaktus wrote: Sun Apr 30, 2023 2:15 pm Roy can I ask for a link to the Polish hisrotic version?
https://wiki.freecad.org/index.php?titl ... id=1256920
Sorry for the inconvenience. The procedure is not as straightforward as I thought.
kaktus
Post by kaktus »
Thank you for your support. ;)
Every cloud has a silver lining.
david69
Post by david69 »
1Roy, if it is "only" renaming and no changes in the wording, one can save all the translation in a file .
The day the page 0.21 is created, we just need to copy/past the blocks in the new page.
it should work.
