Use a steady state result as an initial condition to a transient simulation
Moderator: oliveroxtoby
I have read that it sometimes would be a benefit to use the result obtained from a steady state calculation as an initial condition for a transient calculation.
This should be possible by using "latestTime" as startTime ?
However, if I change the setting from a "steady state" to some "transient" settings and press "write" under "case settings" all the steady state results are wiped away (which also normally makes sense).
Would it be possible to create some functionality which makes it "easy" to re-use a set of simulation results (i my case stored in 64 sub-folders - one for each processor ! ) either to continue a transient simulation or use the steady state result as a initial condition for a transient calculation ?
- Hopes it makes sense
/Rene'
/Rene'
- oliveroxtoby
Re: Use a steady state result as an initial condition to a transient simulation
It would certainly be possible. Someone would just have to do it! ;-)ReneSci wrote: ↑Fri Apr 28, 2023 10:38 am Would it be possible to create some functionality which makes it "easy" to re-use a set of simulation results (i my case stored in 64 sub-folders - one for each processor ! ) either to continue a transient simulation or use the steady state result as a initial condition for a transient calculation ?
- Raedchen_im_System
In my opinion this is an advanced feature and should not be included in "Basic Features" of CfdOf. If you want to do an analysis of this kind, you can easily edit the controlDict file. There are many video tutorials showing how to edit the input files for OpenFoam. Have fun with these tutorials and tell us about your success.
I can't get it to work.
One of the problems is that when I change the set of parameters needed to get the transient simulation and press "save" all directories under "case" and "meshCase" are erased and re-written - and thereby also my steady-state result
Dear Sir,oliveroxtoby wrote: ↑Mon May 01, 2023 7:10 pmIt would certainly be possible. Someone would just have to do it!ReneSci wrote: ↑Fri Apr 28, 2023 10:38 am Would it be possible to create some functionality which makes it "easy" to re-use a set of simulation results (i my case stored in 64 sub-folders - one for each processor ! ) either to continue a transient simulation or use the steady state result as a initial condition for a transient calculation ?
I have similar quiestion.
openFoam 2206
FreeCAD 0.20.2
CFDof - latest - do not know where the version can be found
I tried to continue transient simulation from the latestTime and this was unsuccessful.
Then I carried out some investigation.
1. I made simulation to the exact time, i.e. 0.0002 s
2. I changed the startFrom in the controlDict to latestTime
3. I clicked on Run button in the CFDof. (I do not use Write Case. Just Run)
Simulation started, however from Time=0
I checked this a few times - simulation starts from Time=0
This is shown in Report view window. Checking the first output of the simulation also confirms this - simulation starts from initial conditions.
Then I returned the value of startFrom in the controlDict to startTime keyword, while set startTime to 0.0002 s
In this case, Report view window shows Time=0.0002.
However, this simulation was not completed:
In the Report view:0.0: Solver started
100.1: OpenFOAM fatal error: [7] OpenFOAM fatal error: --> FOAM FATAL ERROR: OpenFOAM fatal error: OpenFOAM fatal error: [6] OpenFOAM fatal error: OpenFOAM fatal error: [7] OpenFOAM fatal error: [4] OpenFOAM fatal error: )
101.3: Simulation exited with error
Then I have found in the Report view earlier:// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * //
Create time
11:01:21 Create mesh for time = 0.0002
11:01:21
PIMPLE: Operating solver in PISO mode
Reading thermophysical properties
Selecting thermodynamics package
type heRhoThermo;
mixture pureMixture;
specie specie;
equationOfState perfectGas;
thermo hConst;
transport sutherland;
energy sensibleEnthalpy;
11:01:24 [0]
[0]
[0] --> FOAM FATAL ERROR: (openfoam-2206)
[7]
[5]
[0]
[4]
[7]
[5]
cannot find file "R:/case/processor0/0.0002/p"
So, solver deletes previous data.// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * //
Create time
Decomposing mesh
Removing 8 existing processor directories
11:00:36 Create mesh
By the way, this also happens when latestTime is used.
I am new in openFoam and CFDof.
Therefore, probably, I should do something else to make continuation of the simulation correlctly.
I would be very grateful if someone could help me to resolve this isue.
Thank you in advance.
Sincerely,
Andrey
I have not tried this but I don't see why it would not work:
If I get a chance today, I will try this.
- Run the SS case first without parallelization (i.e. one output folder)
- Change the "Input Case Name" in the solver parameters to something other than "case" (e.g. "case2")
- Change the simulation type to Transient (plus any other relevant parameters)
- Write the solver files to the new folder, the old results should remain in the old folder
- Copy the SS results from the old final result case folder into the new case folder 0 for the transient run
- Run the transient case (without rewriting files)
Hi,markinca wrote: ↑Wed May 24, 2023 2:50 pm I have not tried this but I don't see why it would not work:
Is it important to start first case unparallel for continuation?
In my case, this will lead to incredible long duration of the simulation...
Best regards,
Andrey
If the first run is in parallel, you will get N output file folders (processor0 to processor#). You would then need to combine them into one file for each field so they could go into the 0 folder for the new run. It should be possible to combine them, I just don't have the details on how to do that. You would need to look at the Openfoam output file format and see how they are organized.
Again, I have never done this but it should be possible with some work.
It seems I did itmarkinca wrote: ↑Wed May 24, 2023 3:27 pm If the first run is in parallel, you will get N output file folders (processor0 to processor#). You would then need to combine them into one file for each field so they could go into the 0 folder for the new run. It should be possible to combine them, I just don't have the details on how to do that. You would need to look at the openFOAM output file format and see how they are organized.
It can be made out of CFDof but directly in the OpenFOAM
Following command should be run in OpenFOAM terminal
reconstructPar -case <CaseDir> -latestTime
Here <CaseDir> - full path to the case data
After completion corresponded modification in the controlDict to start from latestTime
It works
Thank you very much for!
Best regards,
Andrey
