Are you talking about the lines in Sketcher's edit mode or the lines outside of Sketcher?
Drawing lines and Dimensions...Waaay too small...How do I?
Re: Drawing lines and Dimensions...Waaay too small...How do I?
In Sketcher Workbench. I've tried every setting I can find. I was able to improve the font size so now I can see the dimensions. The lines are still so thin, it's hard to select them. In all my searching, I'm seeing that this has been a common complaint, yet I haven't found a solution.
OS: Windows 11 Developer Edition
Version: 0.21.0.32985 (Git)
Hash: 5cd377f931312ede305e4c764ba2028b20eaacfd
Python 3.8.16, Qt 5.15.8, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
You can upgrade to 0.21. There is a setting Preferences->Sketcher->Display->ViewScaleRatio which you can increase.
I hope you find it now, this setting is available in 0.20 as well.
Yeah, adjusting the scale ratio did nothing. There is a new release that just posted about 30 min ago so I'm going to try that.
Honestly, I'm surprised that this is an issue. With the vast number of customization settings, and adjustments and everything else that can be done with this system, you wouldn't think that line thickness wouldn't be such an issue.
Here is the info on the latest release I'm using...
OS: Windows 11 Version 2009
As I told you: there is a setting. It just doesn't work on your computer. I suspect that there is an issue with OpenGL or something else with graphics card or its driver.
- Bildschirmfoto 2023-04-29 um 17.05.16.png (55.49 KiB) Viewed 880 times
- Bildschirmfoto 2023-04-29 um 17.05.59.png (53.5 KiB) Viewed 880 times
Crap, and the one thing you said that I was afraid of...OpenGL. Which I do NOT have on my computer. I'm on an ARM processor and the only way I could use this software was through a compatibility app from windows. I'll have to see if there is something I can adjust from there.
CURSES!!!
So, Chris...In looking into this issue further here is what I found on the compatibility. Does anything stand out to what you know about openGL?
This compatibility pack allows more of your favorite OpenCL™ and OpenGL® apps to run on a Windows PC that doesn't have OpenCL and OpenGL hardware drivers installed by default. If a DirectX 12 driver is installed, supported apps will run with hardware acceleration for better performance. This package supports apps that use OpenCL version 1.2 and earlier and OpenGL version 3.3 and earlier.
