Drawing lines and Dimensions...Waaay too small...How do I?
dniezby
Post by dniezby »
I can't see a thing. The lines are so thin, and the dimensions are crazy small. I've been through every "preference" I can find, and nothing seems to improve this. I mean, look at those dimensions...Can you read them? LOL. Keep in mind, this picture is larger than my screen version.
Thanks in advance.
OS: Windows 11 Developer Edition
Version: 0.21.0.32985 (Git)
Hash: 5cd377f931312ede305e4c764ba2028b20eaacfd
Python 3.8.16, Qt 5.15.8, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
GeneFC
Re: Drawing lines and Dimensions...Waaay too small...How do I?
Post by GeneFC »
dniezby wrote: Thu Apr 27, 2023 10:24 pm
This looks a lot like the problem that occurs when using perspective view rather than orthographic view.
Gene
wakyct
Post by wakyct »
That's funny, because dimensions on my sketches are almost comically large.
Maybe it has something to do with screen scaling. My laptop's screen resolution is pretty low (1366x768). Maybe yours is really high?
What does that word mean in FreeCAD? Look in the Glossary.
The issue with perspective view is still present in 0.21. @dniezby, @wakyct, The size handling is highly version dependent (both your FreeCAD infos are missing :( ), so please check this out in 0.21 if anything beyond the perspective view doesn't work as expected.
dniezby
Post by dniezby »
wakyct wrote: Fri Apr 28, 2023 3:24 am That's funny, because dimensions on my sketches are almost comically large.
Maybe. My resolution is 2880 x 1920. I'm on a Surface Pro X
chrisb wrote: Fri Apr 28, 2023 5:18 am The issue with perspective view is still present in 0.21. @dniezby, @wakyct, The size handling is highly version dependent (both your FreeCAD infos are missing :( ), so please check this out in 0.21 if anything beyond the perspective view doesn't work as expected.
Is this what you meant by "FreeCAD infos?" So, are you saying the weekly is too advanced? I should go to the regular release?
OS: Windows 11 Version 2009
dniezby wrote: Fri Apr 28, 2023 2:56 pm Is this what you meant by "FreeCAD infos?"
Yes!
Double No; you have the most recent.
dniezby
Post by dniezby »
Well, the lines are still very hard to see but at least I've been able to improve the dimension size.
Now I just can't tell if I selected a line or now since they're so thin. Especially when I'm over a part and just need to select an inside line or an edge. No one knows a way to make the lines look thicker huh?
wakyct
Post by wakyct »
There is a way, and I often do it when picking vertices. Select the object, and in the Property View panel there are values for line width, point size, etc.
dniezby
Post by dniezby »
wakyct wrote: Fri Apr 28, 2023 8:46 pm There is a way, and I often do it when picking vertices. Select the object, and in the Property View panel there are values for line width, point size, etc.
I'll give this a look...thanks.
dniezby
Post by dniezby »
Okay, I did find an option that SHOULD affect the line width, but it won't do anything. I can change the color of the lines; I can change the size of the points, but the line won't get any thicker. #baffled
It wouldn't be such a problem but it's VERY difficult to select some lines for constraints and for fillets etc. because they're sooooo thin. What about a style sheet? Are there style sheets that can be edited for this manually somewhere?
