I'm looking for a Function (Sorry I Haven't find the option or function to do that) or A macro to Change the Font for every existing Label or Dimension existing in a TechDraw DrawPage.
Thanks a lot
[SOLVED] Macro or Function to change the Font for every Dimension
Re: macro or Function to change the Font for every Dimension
It's not an answer but rather a workaround: You can select all these entities and change all their common properties in a single step.
It's a WorkAround but you cannot select everything with a Ctrl+A , You need to select Each Dimension/Ballon One By one or use a MAcro.
ChatGPT is my new friends :
I'm closed to the result but I cannot modify the value of the Font in this Macro : obj.Font
import FreeCADGui
# browse all objects in the view
for obj in FreeCADGui.ActiveDocument.Document.Objects:
if obj.isDerivedFrom("TechDraw::DrawViewDimension"):
FreeCADGui.Selection.addSelection(obj)
elif obj.isDerivedFrom("TechDraw::DrawViewLabel"):
elif obj.isDerivedFrom("TechDraw::DrawViewBalloon"):
Ctrl+A sure is too much, single selection too tedious. An intermediate possibility is to select ranges with Shift+click, possibly augmented by deselecting single items.
Nevertheless, a macro is the way to go.
Ok Got It !
import FreeCADGui
if obj.isDerivedFrom("TechDraw::DrawViewDimension") or obj.isDerivedFrom("TechDraw::DrawViewBalloon"):
_name=obj.Name
FreeCADGui.ActiveDocument.getObject(_name).Font = "osifont"
elif obj.isDerivedFrom("TechDraw::DrawViewAnnotation") :
_name=obj.Name
FreeCAD.ActiveDocument.getObject(_name).Font = "osifont"
Re: [SOLVED] Macro or Function to change the Font for every Dimension
Final Release
Copy the two files ChangeFontTechDraw.FCMacro and TaskChangeFont.ui into your macro directory.
- ChangeFontTechDraw.FCMacro
- (4.13 KiB) Downloaded 34 times
- TaskChangeFont.ui
- (816 Bytes) Downloaded 34 times
@wandererfan
What do you think about a buttons for:
- Select all dimensions on page
- Select all dimensions on view
- Select all views
And similar like that?
- Select all views
- wandererfan
