Sure, I can continue with this. Do you plan to have this done before the feature freeze?
Generating QM files from TS with cMake
Re: Generating QM files from TS with cMake
https://github.com/wwmayer/FreeCAD/comm ... e_qm_files
This does the .qm file generation for all C++ based extension modules and the core system. Python based modules are not yet moved.
Yes, I’d like to do it before the freeze: I’m doing some work on more automation of the translation process and this is a part of it.
@wmayer would it be OK with you if I create a PR based on your work on this so far? I'd like to increase the cadence and automation of our translation work, and these QM files are bloating the git repo.
I have created a PR of this branch. Unfortunately, it causes a merge conflict with some of the .qm files. I will fix them as soon as possible...
Yes, sorry— I merged the translations this morning, so you will have to “redelete” the QM files. I should have been patient!
