Would a Wiki administrator/contributor please be so kind as to add the following to https://wiki.freecad.org/Fine-tuning page, Option parameters section immediately following Mod/Sketcher/RadiusDiameterConstraintDisplayAngleRandomness (float): Set an angle randomness on the above value. Value is the range of the random angle, centered on base angle. Default is 0 degree -- disabled -- (if no value set) :
Mod/Sketcher/RoundRectangleSuggConstraints (boolean): Set to false to disable the addition of two extra construction points when creating a rounded rectangle
TIA
Note: This was introduced in git commit 562c967 and maybe changed by a subsequent PR but it's worth adding for the time being.
New Sketcher Fine Tuning Parameter
