Wire model to solid
Max360
Wire model to solid
Post by Max360 »
Dear fellow Freecad users.
Since 3 months I have been trying to make a solid model from a DXF wire model so that I can print it in 3d.
It is a complicated model of a modern sailboat.
In the meantime I had to buy a new PC because my laptop couldn't handle it anymore.
After 3 months I'm still banging my head against the wall because I can't get any further.
system i use:
Intel(R) Core(TM) i7-7700T CPU @ 2.90GHz 2.90 GHz
Ram 16,0 GB
Freecad version 0.20.2
I really hope there is someone who can help me with this, I would really appreciate it.
Best regards
thomas-neemann
Re: Wire model to solid
Post by thomas-neemann »
Max360 wrote: Sun Apr 23, 2023 3:43 pm
curves
should be able to
thomas-neemann
here is an example
https://www.youtube.com/watch?v=CgJdHZGHOb8
phpBB [video]
Vincent B
Post by Vincent B »
A search inside the forum with"boat/hull" could give you some hints.
But looking the file you have a mountain of hours to get the hull.
Im surprised about it. Where you go it.
hammax
Post by hammax »
... IMOCA plans in a digestible file size ???
Here a "little sister" => Beneteau "Figaro":
Figaro_1.FCStd
FC.20.1
(794.52 KiB) Downloaded 14 times
thomas-neemann
are these methods useful for you? (curves draft part)
https://www.youtube.com/watch?v=SUeRQBqsbrw
phpBB [video]
hammax
Post by hammax »
... hi Max,
and did you get your printable scaled model of an imoca60?
I'm actually trying to think over HugoBoss line plans to 11th_hour lines
- e.g. 720mm long, like RC-models.
Is it worth the work?
IMOCA_HB_3.FCStd
FC.20.1
(186.82 KiB) Downloaded 7 times
IMOCA_HB.FCStd
FC.20.1
(91.93 KiB) Downloaded 8 times
Max360
Post by Max360 »
Hi Hammax,
Thank you for showing intrest in this topic.
Thanks to thomas-neeman I am finally able to work on the DXF file.
The model is scaled to a length of 130cm, so there's enough working space for all servos and the tilt system for the keel.
I'm not sure what you mean by 11th_hour lines.
I connected all the ribs in a loft, that way i created an ruled surface.
There's still a long way to go, with a lot of going back and forward, but the effort will be payed off when its an rc beast
HB.V5.pdf
(99.72 KiB) Downloaded 43 times
hammax
Post by hammax »
... sorry, I thought you were inside IMOCA60 happenings.
https://www.theoceanrace.com/
IMOCA_HB_4.FCStd
FC.20.1
(798.24 KiB) Downloaded 6 times
