(solved) Bug in fillet or chamfer all function (0.21 master)
- adrianinsaval
Re: Bug in fillet or chamfer all function (0.21 master)
The list is filled as convenience function I think, say you want to fillet all but one edge, instead selecting one by one you select all edges then deselect the one you don't want.
Some kind of filter driven fillet sounds like a nice feature. Could for example be to specify a direction and a deviation angle and all edges pointing within this spherical sector gets a fillet. And it's then updated according to the filter rules when base feature is changed.
How this is not inconsistent? The automatic input (checikng the box) matches only in special cases (same edges before and after a change of the Body) the output (uncheck the box) and pretty always fails to compute or get valid results.
How can the list be convenient when it fails everytime except the special cases (same edges before and after a change of the Body)? You have to recompute it everytime 2 times with knowledge, it fails every 2 times. I do not mean to make only one edge sharp, i mean when you want to edit the fillet in general. WHEN the list matches the actual fillet list, the 2 times recomputing is obsolete, when you want to edit it (e. g. change to fillet all to let us say to 3 edges). The only second valid solution is no list at all when the checkbox is checked.
Greetings
user1234
- adrianinsaval
no special cases, just one single case: at the moment of clicking the checkbox. I tend to agree that it would be better if the list was updated though.matches only in special cases
It is convenient at the moment of creation of the fillet. Nothing more, nothing less.How can the list be convenient
adrianinsaval wrote: ↑Tue May 02, 2023 6:31 pm It is convenient at the moment of creation of the fillet. Nothing more, nothing less.
And in what way? It is grayed out and not editable, you even can not scroll the list.
Greetings
user1234
- adrianinsaval
launch fillet command -> check all edges, list is populated with all edges but is not editable -> uncheck all edges, populated list is now editable again -> deselect undesired edge(s) -> click ok
That is a workaround to mark all edges with a exception, but that is not the intended usecase to mark all.adrianinsaval wrote: ↑Tue May 02, 2023 7:01 pm launch fillet command -> check all edges, list is populated with all edges but is not editable -> uncheck all edges, populated list is now editable again -> deselect undesired edge(s) -> click ok
Anyway, i compiled the today master on this machine where i am and now it works likes it should be.
Greetings
user1234
- adrianinsaval
It think I got confused, I looked again at the PR that introduced this: https://github.com/FreeCAD/FreeCAD/pull/5340
the convenience function is a context menu entry to mark all edges on the list, the list is populated when marking use all edges for compatibility with older versions of freecad where it would not know anything about the use all edges property, if that case it should indeed get updated when the number of edges changes, can you confirm that it is updating in current master and if not please create a github issue?
The behavior is now:adrianinsaval wrote: ↑Tue May 02, 2023 7:51 pm can you confirm that it is updating in current master and if not please create a github issue?
- go to the fillet function dialog
- mark any edges for the list
- check the checkbox Use All Edges --> only the former marked edges are in the list, but greyed out
- change the geometry before the fillet
- go in the fillet task dialog of the made fillet before --> list is the same but grayed out
- uncheck the Use All Edges --> only in the list edges are filleted
Works as expected now! Same with chamfer.
OS: Debian GNU/Linux 11 (bullseye) (X-Cinnamon/lightdm-xsession)
Version: 0.21.0.33049 (Git)
Build type: Unknown
Hash: 691917804fd537155befc1c627bbfa8484ff513b
Python 3.9.2, Qt 5.15.2, Coin 4.0.0, Vtk 9.0.1, OCC 7.7.1
Locale: C/Default (C) [ OS: English/United States (en_US) ]
* Curves 0.6.8
* CurvedShapes 1.0.4
* Assembly4 0.50.1
* QuickMeasure 2022.10.28
Greetings
user1234
- adrianinsaval
I'm confused, that looks like the same behavior that you reported in the OP, and I now do agree that the list should have been updated to have all edges when the base feature was modified, since the objective is to have compatibility with older versions of freecad (this is of course low priority, but still nice to have)
