- load file
- you see a chamfer (checkbox enabled, list grayed out if you go in the task dialog) at the end of the Body which fillet all
- change the the value of occurrences of linear pattern higher (example from 2 to 3)
- looks OK
- doubleclick on the chamfer to go in the taskdialog of the chamfer
- uncheck fillet all
- Body in now not complete chamfered, because the list is still the same of linear pattern before the change (it does not refresh the list)
- same behavior on fillet
OS: Debian GNU/Linux 11 (bullseye) (X-Cinnamon/lightdm-xsession)
Version: 0.21.0.32938 (Git)
Hash: 1f6b257bfa90117299d3aead8c7f263545886ca9
Python 3.9.2, Qt 5.15.2, Coin 4.0.0, Vtk 9.0.1, OCC 7.7.1
* QuickMeasure 2022.10.28
* Assembly4 0.12.6
* CurvedShapes 1.0.4
* Curves 0.6.8
Greetings
user1234
