GeneFC wrote: ↑Mon May 08, 2023 12:14 pm
That has been true for a long time. Simple setting in Preferences.
In fact, we are substantially telling same thing.
I'm simply saying that there is no need to delete a WB from sources only to have less cluttered interface, as it is easy to have them "hidden" from the interface.
The other matter is that is a reasonable approach to delete obsolete and deprecated WB if there is no good reason to keep them, as example for compatibility reason.
This will easier things to maintainer to as example keep codebase in line with new compilers requirements.
The simple fact that "most users don't use them" as some users as brought as a good reason, lead to the fact that is difficult guess even "how much users" are using FreeCAD, so every decision should even consider that many times the "noise created by unsatisfied" users are difficult to compare with "silent majority" of happy users, and you could only make a decision if you know the two figures to make a comparison.
Sadly in OpenSource is difficult to guess how much "satisfied users" a program have, as it is difficult to count as example how much users are using "distribution supplied" packages, so you should take in account even the above sociological approach about "noisy minority" and "silent majority".
Kind Regards
