I didn't comment the whole line but removed the robot bit. Path builds and works fine. If someone already has a PR in process, please proceed. Otherwise, I'll submit one.Zolko wrote: ↑Tue May 02, 2023 6:29 amand what happens when you comment that line out ?adrianinsaval wrote: ↑Tue May 02, 2023 1:43 am @sliptonic yes I just tried it and get this in cmake output:Code: Select all
REQUIRES_MODS(BUILD_PATH BUILD_PART BUILD_MESH BUILD_ROBOT)
Shipped Modules with FreeCAD
- sliptonic
Re: Shipped Modules with FreeCAD
- sliptonic
At Fosdem there was a lot of discussion about the need for a 'first run wizard' which would tailor the environment for the user on startup. There's a lot of overlap with what you're describing. A first-run wizard goes a bit further in also configuring units, locale, theme, etc. There's a lot of consensus on the general idea which is why it's included in the roadmap. This should absolutely be a V1.0 priority.Zolko wrote: ↑Sun May 07, 2023 9:01 am
The general idea is that I'd like to have a minimalistic core FreeCAD, that can be extended vie the AddonManager to include those modules that are really needed and which is one of the real strength of FreeCAD. I'd also like to see this combined with a "Profile" section in the AddonManager where high-level profiles could be defined, and that would then include several modules to make up such a profile : FEM, architecture, design, 3D print and CNC ... The advantage of a minimalistic core FreeCAD would be to concentrate on performance and stability, and let the extra features be handled by additional modules made for (and by) target user groups.This idea is of course nothing new, and is similar to what Linux distributions and MS-Office installers already practice.
As far as evaluating the current workbenches, the decision is more than just whether it's python or C++.
- The main criteria should be whether it's a core part of the user experience. If most user's are likely to need it, it should be part of the core experience.
- How central the functionality is to many different user workflows.
- We should also consider how much maintenance it's getting (one developer vs many)
- How consistent the UI is with the rest of FreeCAD
For each of the WBs in your list, we could consider one of five actions:
- Remove it from the source (like raytracing)
No value to users, deprecated or replaced by something better. No value to most developers. Not getting any attention.
- Relegate it to an addon repo
Some value to some users. Very niche use-case. Non-standard UI. One (or very few) developers working on it.
- Leave it in the source but disable it from the standard build
Experimental/In (active) development. Useful to developers.
- Leave it in source and in the standard build but disable it from view (at least for some users).
Useful functionality. Well-maintained source. Niche use-case.
- Leave it in, build it, turn it on.
Useful by many/most users. Broadly maintained.
I suggest we also consider which workbenches are needed that don't exist today or are insufficient.
The main thing that the OpenSCAD WB supplies is import of CSG and SCAD files -- in fact, @keithsloan52 already maintains an Addon that provides this. My sense of where the built-in Mod falls in @sliptonic's taxonomy is "Some value to some users. Very niche use-case. Non-standard UI. One (or very few) developers working on it." I'm open to removing it.
If I recall correctly OPENSCAD has a lot of functions used in python for other workbenches ...chennes wrote: ↑Sun May 07, 2023 7:12 pm The main thing that the OpenSCAD WB supplies is import of CSG and SCAD files -- in fact, @keithsloan52 already maintains an Addon that provides this. My sense of where the built-in Mod falls in @sliptonic's taxonomy is "Some value to some users. Very niche use-case. Non-standard UI. One (or very few) developers working on it." I'm open to removing it.
Just for information, how much dropping this would save in terms of file size?
Every now and then I use OpenSCAD ReplaceObject and OpenSCAD RemoveSubtree. There is now a parametric refine in Part workbench, but some people may prefer the tree representation of OpenSCAD RefineShapeFeature.
I'm not on PC now, but IIRC there are many functions from OPENSCAD used in Draft wb
As pointed out on the first page of this topic, the entire exercise is largely academic, with little practical value. The overwhelming contributors to the size of the download package are core functions. Removing a few MB here and there may make sense if the WBs are not used, but there will be no noticeable impact to the resulting download size.
(I am not defending any of the proposed removals.)
Gene
I just checked ... OPENSCAD is about 2MB of 2.2GB (FC unzipped on win) ... we are talking about defeating FC installer for nothing at all.GeneFC wrote: ↑Sun May 07, 2023 9:55 pm As pointed out on the first page of this topic, the entire exercise is largely academic, with little practical value. The overwhelming contributors to the size of the download package are core functions. Removing a few MB here and there may make sense if the WBs are not used, but there will be no noticeable impact to the resulting download size.
Gene
It's not just about the size, it's also about clarity. Concerning size it woule be even more neglectable if the non OpenSCAD functions I mentioned above would be moved to Part workbench.
it is also to let users not complains about missing features... why removing something useful and well known just to resize of 0.1%...
OPENSCAD has a lot of useful python functions in:
OpenSCAD2Dgeom
OpenSCADCommands
OpenSCADFeatures
OpenSCADUtils
What's the point of moving these already established functions as default FC functions to a different container, making the WB programmer's life hell?
