Some questions about cfmesh. Cant find the answer in the user manual.
I want to reconstruct the WD-mesh from above (the circle, here: quadrat),
using 6 volume refinement-levels and 1 surface-refinement. See pic below,
the wing is in the middle of the refinement cubes.
1.:
How are the integers (blue) computed?
In the GUI I can use real numbers (gray background), which I cant see in the meshdict-file.
2.:
When using the written default meshdict, cfmesh consumes > 16 GB RAM,
even without surface refinement/boundary-layers.
3.:
When editing the meshdict after writing and using the red integers, meshing works, 6GB Ram.
But the mesh is to coarse.
4.:
When using a mesh refinement number below 0,001, cfmesh shows a red warning string for a few seconds
"You should not go below 0,001 refinement", something like this), starts the mesher but hangs after a while.
5.:
When the max refinement level is 0,001, compared to max cell size, and I need a cell of 0,5 mm diameter at the wing,
my max-cell-size is 500 mm. Right?
The meshing problem looks easy, in fact very hard, for my taste...
- refinementlevel_integers.JPG (138.24 KiB) Viewed 1299 times
