The fix works. Meshes are much cleaner visually as well as statistically. Good work, Oliver.oliveroxtoby wrote: ↑Thu Apr 06, 2023 3:11 pmThere was an issue with the extrusion. I have pushed a fix.
17:26:14 ***Max skewness = 4.06910924726898, 1 highly skew faces detected which may impair the quality of the results
<<Writing 1 skew faces to set skewFaces
17:26:14 Coupled point location match (average 0) OK.
Checking faces in error :
17:26:14 non-orthogonality > 90 degrees : 0
17:26:14 faces with face pyramid volume < 0 : 0
17:26:14 faces with concavity > 90 degrees : 0
17:26:14 faces with area < 0 m^2 : 0
17:26:14 faces with skewness > 50 (internal) or 100 (boundary) : 0
17:26:14 faces with interpolation weights (0..1) < 0.0001 : 0
17:26:14 faces with volume ratio of neighbour cells < 0.0001 : 0
17:26:14 faces on cells with determinant < 0 : 0
Failed 1 mesh checks.
