help. All new constraints are hidden.
BartR
Post by BartR »
On Freecad 0.20.2 official release, while I was designing, I think I did something wrong and all of sudden, by default, all the new constraints are hidden.
I have to make them manually visible.
Any suggestion please?
______________
Bart R.
Re: help. All new constraints are hidden.
Did you restart FreeCAD? You can try to reset the configuration with the button in the preferences. Another possibility is to delete your config files or to move them in case you want to restore them.
BartR
Post by BartR »
chrisb wrote: Sun Apr 02, 2023 8:59 am Did you restart FreeCAD? You can try to reset the configuration with the button in the preferences. Another possibility is to delete your config files or to move them in case you want to restore them.
I no want to reset the configuration since I chagned all the colors etc. I
What I know is taht I was pushing several time sCTRL+Z e probably i wrong something up there
______________
Bart R.
BartR wrote: Sun Apr 02, 2023 9:10 am I no want to reset the configuration since I chagned all the colors etc. I
You can at least try and see if it fixxes the issue. Then restore it if you so wish.
BartR
Post by BartR »
chrisb wrote: Sun Apr 02, 2023 9:28 am
Something strange occurs. It does only on that sketch. In all the other creates sketches it works fine.
______________
Bart R.
BartR wrote: Sun Apr 02, 2023 10:05 am Something strange occurs. It does only on that sketch. In all the other creates sketches it works fine.
Upload the file for further investigation.
Shalmeneser
Post by Shalmeneser »
Sometime all constraints dissappear.
Sometime closing the sketch and reopening it works.
Sometime Ctrl-Z works.
bambuko
Post by bambuko »
Shalmeneser wrote: Sun Apr 02, 2023 11:17 am Sometime all constraints dissappear.
yes, I have noticed it recently as well
Grub
Post by Grub »
Sketcher SwitchVirtualSpace Image
Shortcut : Z,Z
If I understand OP right, the problem is not to unhide them, but that they are hidden right after creation.
