Hi!
I'm trying to reference a position (xyz in GCS) as an offset for a datum line (attachment offset), I'm sure there should be a way to convert from global coordinates to object mapping coordinates, but can't find it. Maybe could someone provide some info regarding this?
Thanks!
Javier.
Convert from global coordinates to attachment offset coordinates
FreeCAD scripts, animations, experiments and more: http://linuxforanengineer.blogspot.com.es/
Open source CNC hot wire cutter project (NiCr): https://github.com/JMG1/NiCr
Exploded Assembly Workbench: https://github.com/JMG1/ExplodedAssembly
Re: Convert from global coordinates to attachment offset coordinates
the following code moves the Datum Line. If the vector is collinear with the Datum line, the length of the line is changed.
DL.AttachmentOffset.Base.add(FreeCAD.Vector(10,0,0));App.activeDocument().recompute(None,True,True)
- DL.FCStd
- (10.02 KiB) Downloaded 12 times
Here's an example. Cylinder001 is attached to Cube. I want to change its attachment offset so that it coincides with CylinderJMG wrote: ↑Sat Apr 01, 2023 10:58 pm Hi!
Thanks!
Javier.
doc= App.ActiveDocument
cyl = doc.getObject('Cylinder')
cyl001 = doc.getObject('Cylinder001')
gt = cyl.getGlobalPlacement()
gp = cyl001.getGlobalPlacement()
ap = cyl001.AttachmentOffset
apnew = ap * gp.inverse() * gt
cyl001.AttachmentOffset = apnew
doc.recompute()
I'm assuming you don't use links, where getGlobalPlacement() doesn't work as desired.
- changeAttachment.FCStd
- (5.69 KiB) Downloaded 16 times
Thanks for your help!
Here you have the macro that required it: it creates approximated sheet metal bends using datum lines and revolutions, works by selecting one side face (one that has two edges as sheet thickness) and then the edge of the direction you want the bend to go.
import math as mt
def add_sm_bend(angle=90):
operation = FreeCAD.Gui.Selection.getSelection()[0]
body = operation.Body
for i, obj in enumerate( FreeCAD.Gui.Selection.getSelectionEx()[0].SubObjects):
if obj.ShapeType == "Face":
face = obj
face_name = FreeCAD.Gui.Selection.getSelectionEx()[0].SubElementNames[i]
if obj.ShapeType == "Edge":
datum_edge = obj
# detect sm thickness
sm_thk = round(min([i.Length for i in face.Edges]),4)
#sm_v = sm_edge.valueAt(0.0)-sm_edge.valueAt(sm_edge.Length)
#radius_vector = (sm_v).normalize()
radius_vector = (datum_edge.valueAt(datum_edge.Length/2)-face.CenterOfMass).normalize()
rev_offset = radius_vector*sm_thk*1.5
def find_edge_ID(obj,edge):
for i, edge in enumerate(operation.Shape.Edges):
if round((edge.CenterOfMass - datum_edge.CenterOfMass).Length, 6) == 0:
edge_name = "Edge"+str(i+1)
return edge_name
# create datum line
bend_axis = body.newObject('PartDesign::Line','BendAxis')
bend_axis.AttachmentSupport = [operation, find_edge_ID(operation,datum_edge)]
bend_axis.MapMode="TwoPointLine"
FreeCAD.ActiveDocument.recompute()
ax_plm = FreeCAD.Placement( (rev_offset + face.CenterOfMass), face.Rotation)
bend_axis.AttachmentOffset.Base = (bend_axis.getGlobalPlacement().inverse()*ax_plm).Base
bend_axis.ViewObject.Visibility = False
# create revolution
rev = body.newObject('PartDesign::Revolution',"SMBend")
rev.Profile = (operation, face_name)
rev.ReferenceAxis = bend_axis
rev.Angle = angle
# check for inverted bend (there should be a better way to get auto-intersection,but..)
bend_volume = mt.pi*((2*sm_thk)**2-sm_thk**2)*datum_edge.Length*(angle/360)
new_ok_v = operation.Shape.Volume + bend_volume
new_v = rev.Shape.Volume
rev.Reversed = round(new_ok_v,3)> round(new_v,3)
add_sm_bend(60)
