[Solved] CSV help
jfc4120
[Solved] CSV help
Post by jfc4120 »
  * Help 1.0.3
This little test file works:
# -*- coding: utf-8 -*-
import FreeCAD,FreeCADGui
import Draft
import math
import csv
from PySide import QtGui
WIRE = True
INPUTININCHES = True
if INPUTININCHES:
    convert = 25.4
else:
    convert =1.0
getDouble = QtGui.QInputDialog.getDouble
Vector, Placement = App.Vector, App.Placement
doc = App.ActiveDocument
FIELDS = ["Number_sides", "Factor"]
with open('c:\\mydocs\\factor.csv', "r") as f:
    mycsv = csv.DictReader(f)
    for row in mycsv:
        if row["Number_sides"] == "16":
            print(row["Factor"])
            break
It gives expected value in the print.
However this one gives nothing, no response, any idea why not?
import Draft
import math
import csv
WIRE = True
if INPUTININCHES:
    convert = 25.4
else:
    convert =1.0
sel = Gui.Selection.getSelectionEx()
start_point = Vector(0, 0, 0)
if sel:
    sel, = sel
    if sel.PickedPoints:
        start_point = sel.PickedPoints[-1]
FLAG=0
TCLRD, tclrdflag = getDouble(None, 'example', 'Radius', decimals=3)
#TCLRD *= convert
BASEON, baseonflag = getDouble(None, 'example', 'POLYGON number of sides 12, 16, 24, 36, 48', decimals=0)
    for row in mycsv:
        based = str(BASEON)
        if row["Number_sides"] == based:  # a hard coded number works
            break
Edit:
Got it I had to:
based = str(int(BASEON))
It was reading like 12.0 instead of 12. Sorry I found an S.O. post after posting.
