Spreadsheets and Constraints
Very new to FreeCAD, need help with simple issue: Basically, can I pull data into a spreadsheet from a sketch, do calculations on it, and feed those results back out to constrain other elements in the sketch. For example, I drew two lines at random acute angles attached to x-axis. Created a spreadsheet with two entries, angleleft and angleright, no aliases set yet. In the sketch, I put a constraint on the left angle to 30°and named it anglel. In the Spreadsheet, the cell next to angleleft (in this case B1) is set =Sketch.Constraints.anglel, this is fine and it pulls in the 30°. The cell next to angleright (B2) is then given the alias angler. The value of B2 is set to B1/2 which shows 15°, all is fine so far. Back in the sketch I attempt to set the right line angle using the angle constraint and formula editor, however, the Spreadsheet does not appear in the list, and I get errors for Spreadsheet.Constraints.angler. Tried using two different spreadsheets, no improvement. Any ideas would be appreciated.
Re: Spreadsheets and Constraints
You cannot use the same spreadsheet for input and output of the same sketch.
Thank you for the info. I did also read that in the Formula editor description which advised to used two different spreadsheets. I created a read and write spreadsheet to do the same task, this does not work either.
- adrianinsaval
you don't really need a spreadsheet to do calculations, you can do math directly on the constraints expressions and you can reference other constraints within the sketch.
Besides, that, Spreadsheet.Constraints doesn't make sense, that's the nomenclature for sketches, when referencing a spreadsheet cell use the cell directly or it's alias, for example Spreadsheet.B2 or Spreadsheet.angler but if this value is based on a constraint value from the same sketch this woul create a circular dependency which isn't allowed.
