I have been using part design to create different bodies. I then realized I would need them to slot in a male/female way.
The female part is a cylinder with a conic bottom. Can I use subshape binder to bring in that negative space and fill it with something like pad to create the male part?
The benefit I am seeking is that if I modify the size or some other attribute that both will maintain the same shape.
Thank you!
Using PartDesign SubShapeBinder to create male/female parts?
Re: Using PartDesign SubShapeBinder to create male/female parts?
You can use a subshapebinder or shapebinder to do a boolean cut of the mating part to define the profile.
It is all in how you structure your parts.
Here's a simple example of mating pieces sharing a common sketch.
- Sharedsketch.FCStd
- (15.83 KiB) Downloaded 11 times
Thanks so much @edwilliams16 I did not know you could do this!
As a followup, what would be the best way to create a synchronized multiple of this say for creating a box enclosure with one in each corner? I don't want to do a copy but I am unsure of the cleanest way to do this as I would need to attach it to the two bodies I already have.
Make a foot and use Part Design|Multitransform to reflect the feet. Use expressions or common sketches to relate matching parts.
- multitransform.FCStd
- (18.17 KiB) Downloaded 9 times
- Screenshot 2023-04-04 at 4.57.23 PM.png (17.07 KiB) Viewed 339 times
Thanks so much @edwilliams16 this is very helpful and will save design complexity.
