TechDraw parentheses for reference dimensions
ytrottier
Post by ytrottier »
How do I put parentheses around a dimension? I want to show some dimensions as reference only.
OS: macOS Mojave (10.14)
Version: 0.20.2.29603 (Git)
Locale: C/Default (C)
  * Assembly4 0.12.6
Roy_043
Re: TechDraw parentheses for reference dimensions
Post by Roy_043 »
Add them in the Format Spec field.
ytrottier
Post by ytrottier »
I tried putting (%.2w) in the Format Specifier field, but the parentheses don't show up.
user1234
Post by user1234 »
ytrottier wrote: Sat Apr 01, 2023 8:50 pm I tried putting (%.2w) in the Format Specifier field, but the parentheses don't show up.
This should work exactly this way, have you a file?
Greetings
user1234
ytrottier
Post by ytrottier »
Here it is. Any comments welcome. I know drafting, but new to FreeCAD and struggling.
design.FCStd
(238.01 KiB) Downloaded 22 times
user1234
Post by user1234 »
ytrottier wrote: Sat Apr 01, 2023 9:41 pm Here it is.
Works flawless. Could it be, that you looking on the wrong dimension? There was already a parentheses on Page003 --> ProjGroup005 --> Front005 --> Dimension101.
Greetings
user1234
ytrottier
Post by ytrottier »
Is there something I have to refresh or is it a bug?
Screen Shot 2023-04-01 at 5.58.32 PM.png (995.9 KiB) Viewed 762 times
wakyct
Post by wakyct »
I see the same issue as @ytrottier — the error is "15:00:20 Warning - no numeric format in formatSpec (%.2 - Dimension". Which may be an error only as it analyzes the field character by character? But in any case, clicking OK in the property editor and there are no parens.
no_parens_techdraw_example.FCStd
(18.21 KiB) Downloaded 22 times
What does that word mean in FreeCAD? Look in the Glossary.
user1234
Post by user1234 »
Can you test it on the 0.21 weekly builds? As i see, you use imperial units. Maybe it is a bug, which is already solved in the 0.21master version.
Greetings
user1234
Moved to TechDraw forum.
