Suggestions on clipping function in Sketcher
saline
Post by saline »
Version: 0.21.31058 (Git)
Hash: e6c53d8642af36ce7d738ab6058b063ec58e0859
Python 3.8.13, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
  * A2plus 0.4.60g
  * ExplodedAssembly
  * fasteners 0.4.51
  * Help 1.0.3
  * sheetmetal 0.2.60
  * ThreadProfile 1.84.0
I'm trying to pad an oblong shape on a surface. It consists of 2 circles at either end, joined by 2 tangential radii.
Hose-oblong.FCStd
(11.17 KiB) Downloaded 9 times
The problem is the tail that I can't figure out how to clip. I created this by generating 2 equal circles then with a constricted radius did tangential joins at each of 4 corners. I then used the clip function to clip away the parts I didn't need. The problem is that there is no point on the lower right tangent to clip away the little tail. I've tried to un-constrict several constrictions and re-tangent, but nothing gives me a clip point at the lower left. Any suggestions?
I'm thing it is a resolution problem because the large radius is represented as line segments and FreeCad can't attach it at the exact point.
user1234
Re: Suggestions on clipping function in Sketcher
Post by user1234 »
I would not clip it anyway, because clipping make no tangential constraint. Make 4 arc circles and connect them via tangential constraint. Works in no time.
Greetings
user1234
GeneFC
Post by GeneFC »
I don't understand the problem.
Clip, clip and I am done. About 15 seconds. Pads fine.
Gene
saline
Post by saline »
It's a mystery to me then. I don't know what you did differently. I'll scrap it and start again, but I see you got all 4 of your tangents to show up. 2 of mine when away.
I made the 2 smaller circles, constrained the small circle diameters and distance, made the larger circles, and made tangents at each of the 4 locations. I tried it with and without the larger circles constrained.
