Build error about linking salomesmesh:
[ 1%] Building CXX object src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/src/SMDS/duplicate.cpp.o
[ 1%] Linking CXX shared library ../../../lib/libSMDS.so
/usr/bin/ld: cannot find -lVerdict::verdict: No such file or directory
/usr/bin/ld: cannot find -lnlohmann_json::nlohmann_json: No such file or directory
clang-15: error: linker command failed with exit code 1 (use -v to see invocation)
make[2]: *** [src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/build.make:814: lib/libSMDS.so] Error 1
make[1]: *** [CMakeFiles/Makefile2:2230: src/3rdParty/salomesmesh/CMakeFiles/SMDS.dir/all] Error 2
make: *** [Makefile:136: all] Error 2
-- Found OpenGL: /usr/lib/libOpenGL.so
-- Found OpenGLU: /usr/lib/libGLU.so
CMake Deprecation Warning at /usr/lib/cmake/vtk/vtk-config.cmake:75 (message):
The new name for the 'vtkCommonCore' component is 'CommonCore'
Call Stack (most recent call first):
cMake/FreeCAD_Helpers/SetupSalomeSMESH.cmake:29 (find_package)
CMakeLists.txt:60 (SetupSalomeSMESH)
-- Found JsonCpp: /usr/lib/libjsoncpp.so (found suitable version "1.9.5", minimum required is "0.7.0")
-- Found HDF5: /usr/lib/libhdf5.so;/usr/lib/libsz.so;/usr/lib/libz.so;/usr/lib/libdl.a;/usr/lib/libm.so (found version "1.14.0") found components: C HL
CMake Warning at /usr/lib/cmake/vtk/VTK-vtk-module-find-packages.cmake:1966 (find_package):
By not providing "Findnlohmann_json.cmake" in CMAKE_MODULE_PATH this
project has asked CMake to find a package configuration file provided by
"nlohmann_json", but CMake did not find one.
Could not find a package configuration file provided by "nlohmann_json"
with any of the following names:
nlohmann_jsonConfig.cmake
nlohmann_json-config.cmake
Add the installation prefix of "nlohmann_json" to CMAKE_PREFIX_PATH or set
"nlohmann_json_DIR" to a directory containing one of the above files. If
"nlohmann_json" provides a separate development package or SDK, be sure it
has been installed.
/usr/lib/cmake/vtk/vtk-config.cmake:152 (include)
cMake/FreeCAD_Helpers/SetupSalomeSMESH.cmake:53 (find_package)
CMake Warning at /usr/lib/cmake/vtk/VTK-vtk-module-find-packages.cmake:2013 (find_package):
By not providing "FindVerdict.cmake" in CMAKE_MODULE_PATH this project has
asked CMake to find a package configuration file provided by "Verdict", but
Could not find a package configuration file provided by "Verdict"
(requested version 1.4.0) with any of the following names:
VerdictConfig.cmake
verdict-config.cmake
Add the installation prefix of "Verdict" to CMAKE_PREFIX_PATH or set
"Verdict_DIR" to a directory containing one of the above files. If
"Verdict" provides a separate development package or SDK, be sure it has
been installed.
-- Configuring done (15.1s)
CMake Error in src/3rdParty/salomesmesh/CMakeLists.txt:
Imported target "VTK::hdf5" includes non-existent path
"/build/hdf5-openmpi/src/hdf5-1.14.0/src/H5FDsubfiling"
in its INTERFACE_INCLUDE_DIRECTORIES. Possible reasons include:
* The path was deleted, renamed, or moved to another location.
* An install or uninstall procedure did not complete successfully.
* The installation package was faulty and references files it does not
provide.
CMake Error at /usr/lib/cmake/vtk/VTK-targets.cmake:555 (set_target_properties):
The link interface of target "VTK::nlohmannjson" contains:
but the target was not found. Possible reasons include:
* There is a typo in the target name.
* A find_package call is missing for an IMPORTED target.
* An ALIAS target is missing.
/usr/lib/cmake/vtk/vtk-config.cmake:138 (include)
CMake Error at /usr/lib/cmake/vtk/VTK-targets.cmake:1943 (set_target_properties):
The link interface of target "VTK::verdict" contains:
Verdict::verdict
-- Generating done (0.4s)
CMake Generate step failed. Build files cannot be regenerated correctly.
Config summary:
System
-- bindir: bin
-- BLAS: -undefined-
-- CMAKE_VERSION: 3.26.1
-- Compiler: /usr/bin/clang++ (15.0.7)
-- datadir: share
-- docdir: share/doc/FreeCAD
-- includedir: include
-- libdir: lib
-- prefix: /usr/local
-- Python: 3.10.10 [/usr/bin/python3] Suffix: [.cpython-310-x86_64-linux-gnu]
Config
-- BUILD_FEM: ON
-- BUILD_GUI: ON
-- BUILD_SMESH: ON
-- BUILD_START: ON
-- BUILD_TECHDRAW: ON
-- BUILD_TEST: ON
-- BUILD_VR: OFF
-- BUILD_WEB: ON
-- CMAKE_BUILD_TYPE: Release
-- CMAKE_CXX_FLAGS: -Wall -Wextra -Wpedantic -Wno-write-strings -O2 -march=native -pipe -Wno-undefined-var-template
-- CMAKE_CXX_STANDARD: 17
-- CMAKE_INSTALL_PREFIX: /usr/local
-- CMAKE_PREFIX_PATH: OFF
-- FREECAD_CREATE_MAC_APP: -undefined-
-- FREECAD_LIBPACK_USE: OFF
-- FREECAD_QT_VERSION: Auto
-- FREECAD_USE_EXTERNAL_KDL: OFF
-- FREECAD_USE_EXTERNAL_SMESH: OFF
-- FREECAD_USE_FREETYPE: ON
-- FREECAD_USE_PYBIND11: OFF
-- PYTHON_EXECUTABLE: /usr/bin/python3
-- PYTHON_LIBRARY: /usr/lib/libpython3.10.so
-- USE_CUDA: -undefined-
-- USE_OPENCV: -undefined-
Libraries
-- Boost: 1.81.0
-- Coin3D: 4.0.1 [/usr/lib/libCoin.so] [/usr/include]
-- Coin3D_DOC: not found
-- DesignerPlugin: not built (BUILD_DESIGNER_PLUGIN is OFF)
-- Doxygen: 1.9.6 Language: English
-- Eigen3: 3.4.0
-- fmt: 9.1.0
-- Freetype: 2.13.0
-- HDF5: 1.14.0
-- Matplotlib: 3.7.1 PathDirs: /usr/lib/python3.10/site-packages/matplotlib
-- MEDFile: 4.1.1 [/usr/lib/libmedC.so;/usr/lib/libmed.so] [/usr/include]
-- NETGEN: not enabled
-- OCC: 7.6.3 [/usr/lib] [/usr/include/opencascade]
-- OCC_Libs: [TKFillet;TKMesh;TKernel;TKG2d;TKG3d;TKMath;TKIGES;TKSTL;TKShHealing;TKXSBase;TKBool;TKBO;TKBRep;TKTopAlgo;TKGeomAlgo;TKGeomBase;TKOffset;TKPrim;TKSTEPBase;TKSTEPAttr;TKSTEP209;TKSTEP;TKHLR;TKFeat]
-- OpenGL_Lib: [/usr/lib/libGL.so]
-- OpenGLU_Incl: [/usr/include]
-- OpenGLU_Lib: [/usr/lib/libGLU.so]
-- pivy: 0.6.8
-- pybind11: not enabled
-- PYCXX: 7.1.7 Incl: ...FreeCAD/src Src:.../FreeCAD/src/CXX
-- PySide: 5.15.8 [/usr/include/PySide2]
-- PySideTools: v: 2 uic: [/usr/bin/uic] rcc: [/usr/bin/rcc]
-- QtConcurrent: 5.15.8
-- QtCore: 5.15.8
-- QtNetwork: 5.15.8
-- QtOpenGL: 5.15.8
-- QtPrintSupport: 5.15.8
-- QtSvg: 5.15.8
-- QtUiTools: 5.15.8
-- QtWebEngineWidgets: 5.15.13
-- QtWidgets: 5.15.8
-- QtXml: 5.15.8
-- Rift: not enabled (BUILD_VR)
-- Shiboken: 5.15.8 [/usr/include/shiboken2;/usr/include/python3.10]
-- SMESH: 7.7.1.0 build internal
-- SPNAV: not found
-- SWIG: 4.1.1
-- VTK: 9.2.6
-- XercesC: 3.2.4 [/usr/lib/libxerces-c.so] [/usr/include]
-- ZLIB: 1.2.13
