Spreadsheet cell value behaving oddly
Jonathan8146
Post by Jonathan8146 »
Version: 0.20.1.29410 (Git)
Branch: releases/FreeCAD-0-20
  * fasteners 0.4.55
  * Help 1.0.3
Not sure if this is the correct place but couldn't find a better option or a similar issue.
I am parameterising my design and am starting in the spreadsheet.
One of my parameters has a value of 8.2 but the spreadsheet always seems to change this to 8.199999999999999. It doesn't seem to upset subsequent calculations based on the cell, but it is a bit disconcerting.
Am I being incredibly stupid, or is this some sort of "feature"?
Roy_043
Re: Spreadsheet cell value behaving oddly
Post by Roy_043 »
This is not unique to FreeCAD. What you see is a normal rounding error caused by floating point conversions. Not every decimal value can be represented accurately in the binary format that computers use internally. This may come as a total surprise, but as already mentioned, this is completely normal. If you don't want to see this then you should just reduce the number of decimals.
See: https://docs.python.org/3/tutorial/floatingpoint.html
Ulicad
Post by Ulicad »
Roy_043 wrote: Sat Apr 01, 2023 4:39 pm ... Not every decimal value can be represented accurately in the binary format that computers use internally. ...
This perrhaps is just curiosity - could you explain, why this value is not represented as 8.200000000000000 ?
Thanks a lot!
Regards, Ulicad / Uli
en: New FC-user, virgin to previous CAD-work, labouring on his new hobby Ulis Blog
de: Neuer FC-Nutzer, ohne vorhergehende CAD-Erfahrung, beschäftigt mit seinem neuen Hobby Ulis Blog
Shalmeneser
Post by Shalmeneser »
d8.2 = b1000.001100110011001100110011001100110011001100110011001100110011001100110011001100110011...
b1000.00110011001100110011 = d8.19999980926513671875
Jonathan8146
Thanks Roy.
I suppose I should have realised this, but I was playing around in Excel, notorious for its "quirky" behaviour, and it was fine so wasn't really expecting it.
Jonathan8146 wrote: Sat Apr 01, 2023 9:36 pm ...
It is simply IEEE floating point, some software do roundings "by design" but this way you introduce another error in the game.
It is a simple matter to know this behaviour. Internally most of FreeCAD is using for his calculations a precision on 1e-7 and internal units are mm so it is not too bad. And is using 64bit floats.
It is an engineering CAD kernel, build to make automotive and aerospace things not to design chips or high precision things. (but even when manufacturing chips are printed using photoreduction so masters are not printed at nm scale).
Kind Regards
Jonathan8146
A good job I am not creating anything requiring much precision then, just a storage box for a tap set.
GeneFC
Post by GeneFC »
This topic has gone in a strange direction.
Two somewhat different items are being discussed.
Precision relates to the number of significant digits, regardless of numerical size (location of the decimal or the number of zeros).
Scale refers to the size in comparison to ordinary units such as meters or mm.
The precision of FreeCAD is limited in several ways to a usable 6 or 7 significant digits. These limits comes from various tolerance values incorporated in the determination of overlap, coincidence, etc. Some come from OCC, some come from the FreeCAD core, and others come from individual workbenches and external libraries.
Scale is usually not a limiter for any ordinary design until the sizes become sub-micron or multi-km. There have been reports of problems in both directions. I believe these are not the same sort of intrinsic limitations seen with precision, but rather choices made while creating various code elements. In that case it may be necessary to create a scaled design and later expand or contract externally.
Gene
openBrain
Post by openBrain »
Jonathan8146 wrote: Sat Apr 01, 2023 2:51 pm One of my parameters has a value of 8.2 but the spreadsheet always seems to change this to 8.199999999999999. It doesn't seem to upset subsequent calculations based on the cell, but it is a bit disconcerting.
While there are technical reasons for this, I can only confirm it's disconcerting and shouldn't be presented to user.
I found the issue and submitted a fixing PR : https://github.com/FreeCAD/FreeCAD/pull/9163
Many thanks for reporting.
Jonathan8146
openBrain wrote: Sun Apr 02, 2023 6:44 pm While there are technical reasons for this, I can only confirm it's disconcerting and shouldn't be presented to user.
Thank you
