Use same profile to sweep along different paths
FCuser0
Post by FCuser0 »
In PartDesign, using "additive pipe", I would like to sweep the same profile along 4 separate paths (not connected to each other).
I succeed in doing this for one edge, but am not sure how to achieve the same with the 4 other edges. If I do these separately, I would have to copy the profile to sweep and attach it to another edge. But how do I do that?
Here is an illustration giving the idea of what I try to do:
Bance
Re: Use same profile to sweep along different paths
Post by Bance »
PD wb has a single solid rule.
papyblaise
Post by papyblaise »
this is not possible with PartDesign since you will have 4 separate objects in the same body which is forbidden
either you make a closed frame and cut the 4 corners in Part Wb
either you make a single side and make a Circular Array in Draft Wb if the sides are equal
2 solutions among others
FCuser0 wrote: Sat Apr 01, 2023 1:50 pm I succeed in doing this for one edge, but am not sure how to achieve the same with the 4 other edges.
It is possible with a (green) SubShapeBinder - as long as the single solid rule is obeyed.
