After having trashed one too many jobs and broken on too many tools, I got motivated to fix the G98 plays like G99 fudge.
https://github.com/FreeCAD/FreeCAD/pull/9153
It adds new keepToolDown property to UI ( as proposed by wsk8 ) and provides both G98 ( respecting retract to safeheight ) and G99 retracting to R value, (similar to existing drilling behaviour).
Hopefully this fits all needs and finally makes this NIST compliant .
Does what I need
PR making drilling paths G98 / G99 compatible with NIST std.
- 3d-KTD-view.png (32.27 KiB) Viewed 781 times
- trashed-tool.jpeg (118.05 KiB) Viewed 788 times
- 3d-view.png (31.45 KiB) Viewed 789 times
Re: PR making drilling paths G98 / G99 compatible with NIST std.
Thanks for taking a look. Apart from that critique, does it fit the bill?
I did not try to test. The concept seems OK, but of course the devil is in the details.
I fully support the idea of trying to adhere to industry standards instead of bending the code to meet some user's particular problem of the day. I believe that drilling, more than anything else in the Path WB, has suffered from "private" tweaks.
Gene
Thanks Gene.
I never got into this before because I thought it was a lot more complicated than it finally was. wsk8's contribution in providing the UI tweeks was a great help. I also didn't realise that all that was needed was to implement what was already codified in NIST standards. Previous discussions gave the impression that coding a solution was just the beginning of an interminable battle over what was needed and how it should be done.
Once I realised all we needed to implement G99 as defined, it became relatively simple.
There has been a resounding silence to my various posts on this problem but hopefully this fix will be integrated.
If not, at least I just have the pain of maintaining a few patches instead of busting my tools and digging holes in my work. I regret not having fixed this earlier.
Thanks for your comments and help on finding a solution.
A very-very long time overdue; Hope this works out! I feel your pain of broken tooling and spoiled/goughed work-pieces.
Thanks geant.
This got merged yesterday. I'm glad to see this finally fixed.
