V0.21 Workbench selector index issue
Roy_043
Post by Roy_043 »
After disabling a workbench on the "Available Workbenches" tab in the Preferences Editor (Preferences_Editor#Available_Workbenches) there is an index issue if you do not restart FreeCAD.
  1. In the Preferences Editor go to Workbenches -> Available Workbenches.
  2. Disable the first WB in the list (Arch WB in my case).
  3. Press OK, but do not restart FreeCAD.
  4. Select the 4th workbench from the selector.
  5. Result: the 5th WB is activated.
Version: 0.21.0.32637 (Git)
Hash: 7fa7cb7f0b222864be7416c683166876eab190bc
Locale: English/United States (en_US) [ OS: Dutch/Netherlands (nl_NL) ]
openBrain
Re: V0.21 Workbench selector index issue
Post by openBrain »
@paddle
paddle
Post by paddle »
I can't replicate this bug. Besides we have a second PR coming on the wb pref page soon, so it may be better to test after this second pr merge.
Roy_043
Post by Roy_043 »
Index error reported in probably a different context:
viewtopic.php?t=77358
paddle
Post by paddle »
Have you tried to clear the preferences to see if this still happens to you?
I had the same with a plain vanilla config. My guess is that something got out of whack when Image workbench was removed.
Roy_043
Post by Roy_043 »
The problem also occurs after deleting user.cfg, but I now notice that the first WB you activate after disabling a WB is correct, subsequent activations show the index error. So the steps are:
  5. Result: Correct WB is activated.
  6. Select the 5th workbench from the selector.
  7. Result: the 6th WB is activated.
  8. Again select the 4th workbench from the selector.
  9. Result: the 5th WB is activated.
openBrain
Post by openBrain »
Roy_043 wrote: Wed Apr 05, 2023 10:50 pm The problem also occurs after deleting user.cfg, but I now notice that the first WB you activate after disabling a WB is correct, subsequent activations show the index error.
Did you open a ticket for this one in GH ? This is quite problematic and still unresolved AFAIK.
Roy_043
Post by Roy_043 »
