Maybe a BUG in Assembly 4
Batucada
Post by Batucada »
OS: macOS 10.16
Version: 0.21.0.32457 (Git)
Hash: 85216bd12730bbc4c3cbf8f0bc50416ab1556cbb
Python 3.10.9, Qt 5.15.8, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Locale: C/Default (C)
  * Behave-Dark-Colors 0.1.1
  * CurvedShapes 1.0.4
  * Help 1.0.3
  * Assembly4 0.12.3
When working in Assembly 4, one cannot avoid using the "Place linked Part" editor. If the basic setting of 5 decimal places is allowed, then this setting should also be adopted by this editor. But far from it, you have to make do with 2 decimal places.
FC Place Linked Part.png (109.67 KiB) Viewed 312 times
I put up with this until I discovered the reprehensible bug inherent in the Assembly 4 system. Because in the view,
FC Assemby Daten.png (118.52 KiB) Viewed 312 times
it was possible to enter the values with the appropriate accuracy. The nasty part of the story is that if you have to switch back to the "Place linked Part" editor because you have forgotten a rotation, the previously set accuracies are lost.
The requirement must therefore be that Assembly 4 adopts the settings in the FreeCAD system and does not make any changes to the entered data.
