Help understanding CONSOLE ERRORS
Trying to understand some of the console errors i get. any help is appreciated
could not attach Project file: exceeds 1 mb limit.
- FREECAD ERRORS.pdf
- (91.86 KiB) Downloaded 15 times
Re: Help understanding CONSOLE ERRORS
Please, never provide a pdf with just a picture : provide directly the picture which will be directly visible in the forum.
You can write less letters in each ShapeString -> file will be lighter.
- Capture d’écran 2023-04-01 004954.jpg (81.35 KiB) Viewed 556 times
Please attach the error output in code tags directly to the post above: easier to read, and especially on my mobile pdfs are always a hassle.
Ooooh i underStand, sorry for pdf. I will try characters In shape string to limit size of project. Will provide project file
Thankx
Thankx
You get the out of scope message when you cross the body border in an unallowed way. Here you must not apply the Part cut to a pad, apply it to the whole body.
Here is the project file. Delete most of the text chars to reduce the file size.
- Drum Badge 1.FCStd
- (209.88 KiB) Downloaded 6 times
You got the quotes wrong.
Select the body in the tree, not in 3D view
sorry chris. I do select from the tree view. what am i not understanding?
I'm extremely sure that you didn't. Your tree looks like this: You must have selected the Pad to be cut, I see no other possibility for it to be there.
This is how it works
- Remove your Cut
- Select first the Body and then the Fusion: - create a Part->Cut:
