Bug: Large number of calculated fields cause cascading warnings
Build-0-Matic
Post by Build-0-Matic »
I thought I had found the problem, but it seems I haven't.
I have a file that was made in the Part Workbench.
Almost all the parts contain some calculated fields for both size and location. There are a lot of cross references which I took great care to ensure they were correct.
But I've noticed that when I try to change one of the specified values (non calculated ones), it triggers a bunch of warnings and depending on what is modified and how high it is in the hierarchy, Freecad refuses to modify some elements or to redo a complete recalculation.
Since the file is too big for the forum, I put it on my Google Drive
https://drive.google.com/file/d/1GBCgSI ... share_link
I'm running Freecad 0.20.2 on Windows 10 64 bit.
Do you think I should submit it to the Github issues forum?
GeneFC
Re: Bug: Large number of calculated fields cause cascading warnings
Post by GeneFC »
Build-0-Matic wrote: Fri Mar 31, 2023 3:01 pm Do you think I should submit it to the Github issues forum?
The very first thing to do is to describe in detail how to create even one error.
I downloaded your file, but it contains a very large number of possible variables.
Which one(s) should a tester try to adjust to see the error?
Gene
Build-0-Matic
Just begin with playing with Camera Body/Body/Camera Body Adds/Main Body Cube and it will trigger errors.
But touching pretty much anything that is not calculated can also do it.
Syres
Post by Syres »
Build-0-Matic wrote: Fri Mar 31, 2023 3:24 pm Just begin with playing with Camera Body/Body/Camera Body Adds/Main Body Cube and it will trigger errors.
Did you do what was specifically asked of you in the last thread which is use the latest 0.21dev version and report back (viewtopic.php?p=671103#p671103), issues are only going to be accepted if they still exist in the latest master?
GeneFC
Post by GeneFC »
I see a lot of "Links go out of scope" warnings.
The Dependency Graph shows a ton of illegal links.
It is not necessary to change anything. A full recompute shows the same problem.
Gene
Build-0-Matic
Syres wrote: Fri Mar 31, 2023 3:40 pm
I had forgotten the thread name. That's what happens when you have too many things to think about.
But yeah, I tried using the weekly build and it gives me the same warnings.
The strange thing is that all the illegal links were not illegal when I made them. So I really don't know how to fix this.
