tool goes up during profile
You can see the pretty simple profiling path as per picture attached.
However, on a particular location the machine won't follow the path and will goes up (diagonally), as you can see in following attached picture.
What could be the reason ?
- Capture d’écran 2023-03-31 à 15.02.33.png (91.35 KiB) Viewed 708 times
- IMG_0808.jpg (761.59 KiB) Viewed 708 times
Re: tool goes up during profile
File? Without it looks like an issue on your machine.
It appears to be a red line signifying a rapid path to a different location. It does not appear to be cutting anything.
The order of cutting steps is decided in various ways. It is not always clear to a human how the strategy was created for a specific shape.
If you include the actual model file and/or g-code file someone may be able to offer a bit more detail.
Gene
Sure ! Sorry for not including these files. Here it is.
- nose_third.FCStd
- (29.87 KiB) Downloaded 16 times
- parametric_ski - mold_nose.step
- (23.39 KiB) Downloaded 13 times
And the knc (rename with .txt extension because this forum won't accept .knc file)
- nose_third_tag_12.txt
- (12.68 KiB) Downloaded 14 times
I took a close look at the files you posted. Everything looks perfect.
As chrisb said, this looks like some sort of problem due to your machine or controller.
Gene
Gene
Thank you for your reply. Do you ave any idea what I should look into ?
I have a Heiz machine, using WinPC-NC software to control it.
This is the first time I see this issue.
I am not familiar with either the machine or the controller. Perhaps some other reader will recognize those items.
I should have added previously that I ran your g-code in Camotics, a cutting simulator that is completely separate and independent from FreeCAD. The cut pattern looked perfect.
Gene
This is a bit off topic: That means you don't see any errors on recomputing the file? I have errors in 0.21 after migrating with the JobFixer script.
10:54:29 Invalid type Path::PropertyTool for property nose_third_current#Tool.Tool
10:54:29 Traceback (most recent call last):
File "/Users/cb/Desktop/FreeCAD.app/Contents/Resources/Mod/Path/Path/Dressup/Gui/Tags.py", line 477, in updateData
self.updatePositions(obj.Positions, obj.Disabled)
File "/Users/cb/Desktop/FreeCAD.app/Contents/Resources/Mod/Path/Path/Dressup/Gui/Tags.py", line 467, in updatePositions
self.obj.Proxy.pointAtBottom(self.obj, p), self.colors
File "/Users/cb/Desktop/FreeCAD.app/Contents/Resources/Mod/Path/Path/Dressup/Tags.py", line 1350, in pointAtBottom
self.setup(obj)
File "/Users/cb/Desktop/FreeCAD.app/Contents/Resources/Mod/Path/Path/Dressup/Tags.py", line 1314, in setup
self.toolRadius = float(PathDressup.toolController(obj.Base).Tool.Diameter) / 2
<class 'AttributeError'>: 'FeaturePython' object has no attribute 'Tool'
File "/Users/cb/Desktop/FreeCAD.app/Contents/Resources/Mod/Path/Path/Tool/Gui/Controller.py", line 122, in claimChildren
if obj and obj.Proxy and obj.Tool:
Can you please retry - I recommend a dry run! - without the tags dressup.
Further tests which could help to identify the problem:
- mill only the front line
- do it in one stepdown
- do a straight line.
