DWG error
izabela.victoria
DWG error
Post by izabela.victoria »
Hello, I'm new to FreeCAD. I've just downloaded it and wanted to open one of my dog projects but there is a communication about the error. Is there any way to open this kind of file instead of the error? Thank you very much and all the best
Re: DWG error
Hi and welcome to the forum!
FreeCAD file? FreeCAD infos? What are you trying to do - step by step? What exactly is the error?
mario52
Re: DWG error
Post by mario52 »
Hi
DWG error
with the files Import DXF gives blank scene
Teigha File Converter 4.3.2
FreeCAD_weekly-builds-32532-2023-03-26-conda-Windows-x86_64-py310
DXF and DWG
20:19:14 Traceback (most recent call last):
File "C:\FreeCAD_weekly-builds-32532-2023-03-26-conda-Windows-x86_64-py310\Mod\Draft\importDWG.py", line 105, in insert
doc = importDXF.insert(dxf, docname)
File "C:\FreeCAD_weekly-builds-32532-2023-03-26-conda-Windows-x86_64-py310\Mod\Draft\importDXF.py", line 2826, in insert
Import.readDXF(filename)
<class 'RuntimeError'>: File doesn't exist
20:22:26 Traceback (most recent call last):
File "C:\FreeCAD_weekly-builds-32532-2023-03-26-conda-Windows-x86_64-py310\Mod\Draft\draftviewproviders\view_dimension.py", line 489, in updateData
rot1 = App.Placement(_plane_rot).Rotation.Q
<class 'TypeError'>: empty parameter list, matrix or placement expected
20:22:26 Cette fonction est obsolète. N'utilisez pas cette fonction directement.
20:22:26 Utilisez une des "make_linear_dimension" ou "make_linear_dimension_obj".
File "C:\FreeCAD_weekly-builds-32532-2023-03-26-conda-Windows-x86_64-py310\Mod\Draft\draftviewproviders\view_dimension.py", line 511, in updateData
rot3 = App.Placement(_plane_rot).Rotation.Q
20:22:26 Cette fonction sera rendue obsolète. Veuillez utiliser 'convert_draft_texts'.
20:22:26 convert_draft_texts
20:22:26 ----------------
20:22:26 Convert Draft texts
mario
thomas-neemann
Re: DWG error
Post by thomas-neemann »
izabela.victoria wrote: Fri Mar 31, 2023 11:16 am ....
do you want to import 2d or 3d dwg files?
izabela.victoria
Re: DWG error
I worked on a project in AutoCAD LT and it is a 2d project, just simple drawings
thomas-neemann
Re: DWG error
izabela.victoria wrote: Fri Mar 31, 2023 9:00 pm I worked on a project in AutoCAD LT and it is a 2d project, just simple drawings
here is a possibility for 2d dwg "import"
https://www.youtube.com/watch?v=PRm7cHF-Gpg
phpBB [video]
izabela.victoria
Re: DWG error
I managed to open it, thank you very much for your help :)
