Rotation Problem using rotateX, rotateY, rotateZ
doxley
Post by doxley »
In a project I'm doing, I need to rotate an LCS such that the z-axis is aligned with the z-axis of a second LCS using two rotations along its primary axes. I'm attempting to do this using the Matrix.rotate(X/Y/Z) with the LCS positioned at the origin. There is obviously a misunderstanding on my part as I'm getting nothing like I intended.
In the example below, I'm using the yaw/pitch/roll angles. I realize that the second and third rotations would be applied to a rotated matrix, so the example would not work as shown (if all three rotations were attempted). However, I did presume that a rotation of only the yaw would return a matrix such that getYawPitchRoll would return a yaw angle equal to what I had applied (if I have misunderstood the XYZ association to YPR, I would still have expected one angle to match).
What I need is to determine the proper angles such that I can successively apply them to achieve the orientation of the z-axis I need (I need to use the rotations in this form to correspond to what is happening physically).
doc = FreeCAD.ActiveDocument
# create a local coordinate system (at the origin) with an arbitrary rotation
lcs1 = doc.addObject('PartDesign::CoordinateSystem', "LCS_1")
rot = FreeCAD.Rotation(40, 62, 38)
lcs1.Placement.Rotation = rot
print(f"LCS1_YPR: {lcs1.Placement.Rotation.getYawPitchRoll()}")
lcs2 = doc.addObject('PartDesign::CoordinateSystem', "LCS_2")
yaw, pitch, roll = lcs1.Placement.Rotation.getYawPitchRoll()
# rotate the second coordinate system to match the orientation of the first
matrix = lcs2.Placement.Matrix
matrix.rotateZ(math.degrees(yaw))
# matrix.rotateX(math.degrees(pitch))       # would be applied to a rotated LCS
# matrix.rotateY(math.degrees(roll))
lcs2.Placement.Matrix = matrix
# print the final orientation of the second coordinate system
print(f"LCS2_YPR: {lcs2.Placement.Rotation.getYawPitchRoll()}")
Any help/corrections/insight would be appreciated.
Thanks,
--Don
OS: Ubuntu 22.10 (ubuntu:GNOME/ubuntu)
Version: 0.20.1.
Python 3.10.7, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
  * Curves 0.5.2
  * Assembly4 0.12.3
  * Manipulator 1.4.9
  * fasteners 0.3.50
Roy_043
Re: Rotation Problem using rotateX, rotateY, rotateZ
Post by Roy_043 »
Change:
to:
matrix.rotateZ(math.radians(yaw))
doxley
Post by doxley »
Thank you @Roy_043 - I changed that twice and still couldn't get it right!! :oops:
That still leaves me with the problem of determining the two rotations that I do need which can be applied successively, though I may be able to figure it out with this crazy mistake out of the way.
Thx,
--Don
Roy_043
Post by Roy_043 »
The order is important:
matrix.rotateX(math.radians(roll))
matrix.rotateY(math.radians(pitch))
doxley
Re: [SOLVED] Rotation Problem using rotateX, rotateY, rotateZ
Post by doxley »
Yes, and I had the pitch and roll axes misassigned.
Thanks for the help - I was going nuts over stupid mistakes.
Cheers,
--Don
doxley wrote: Fri Mar 31, 2023 1:33 pm Yes, and I had the pitch and roll axes misassigned.
Cheers,
--Don
rotateX[YZ]() will modify the Matrix and the changes are "additive", so order is important, see the inverse order.
