Path workbench. Can't create route for single face
Foxhound
Post by Foxhound »
I'm using KiCad for making routes for my CNC.
I try to cut workpiece from one side. Like at the picture below
The problem is that then I create Profile job using only one face from my model, I got error:
<Path.Area> Area.cpp(1317): project failed
<Path.Area> Area.cpp(1459): empty projection
PathProfile.ERROR: Unable to create path for face(s).
list index out of range
How I can fix this?
Version: 0.20.2.29603 (Git)
Branch: releases/FreeCAD-0-20
  * 3D_Printing_Tools
  * A2plus 0.4.60i
  * cura_engine
  * Curves 0.6.6
  * kicadStepUpMod 10.17.1
Re: Path workbench. Can't create route for single face
File?
Foxhound
Post by Foxhound »
Here is the file
TestA.FCStd
(21.52 KiB) Downloaded 13 times
Re: Can't fuse in 1 object
Setting correct values for final depth (and stepdown) works excellent in 0.21. I'm not sure if a profiling single line works already in 0.20.
Foxhound
Post by Foxhound »
And what is the correct depth and stepdown?
You select edge or face to create profile operation?
Foxhound
Post by Foxhound »
I've test in 0.21
The same result
OS: Ubuntu 22.04.2 LTS (ubuntu:GNOME/ubuntu)
Version: 0.21.0.32637 (Git) AppImage
Hash: 7fa7cb7f0b222864be7416c683166876eab190bc
  * A2plus 0.4.60i
Syres
Post by Syres »
@Foxhound Why don't you use a bit of left field thinking and use another solid as I would call a DummyHelper. This was created in 0.20 just to be clear, see attached.
Version: 0.20.2.29690 (Git)
Hash: 05a5df264a52e5799c8a4de90be8c1cb5d00ed1e
Python 3.8.10, Qt 5.12.8, Coin 4.0.0, Vtk 7.1.1, OCC 7.3.0
  * Silk 1.0.0
  * A2plus 0.4.60k
  * CurvedShapes 1.0.4
  * MakerWorkbench 1.0.1
  * freecad.gears 1.0.0
  * Curves 0.6.8
  * PieMenu 1.2.4
  * toSketch 1.0.1
  * Plot 2022.4.17
  * AirPlaneDesign 0.4.0
  * fasteners 0.4.54
  * sheetmetal 0.2.63
TestA_Syres.FCStd
(35.52 KiB) Downloaded 4 times
Foxhound wrote: Sat Apr 01, 2023 6:07 am And what is the correct depth and stepdown?
I can't get this to work with my current version. Will retry with an older one later.
Here we go now (I had selected the lower line and that always works on the wrong side).
- Edit your Profile operation
- clear the base geometry and add the upper edge:
- set FinalDepth to 0
- set StartDepth and FinalDepth to the same value for a single path.
- confirm.
Foxhound
Post by Foxhound »
I managed
I select top edge
Then change start depth to 2, final depth to 0, and step down to 0,5
It's workin for me in 20.1 and 21.0
Снимок экрана от 2023-04-01 17-02-31.png (13.51 KiB) Viewed 378 times
