Pour tester : sélectionnez un pad et un sketch. Lancez la macro et le sketch vient se placer sur le Pad. Le tout sans les problème de dénomination topologique.
# Select a pad and then select a sketch, the sketch will be on the pad
# Select a sketch and then a pad, the pad will be on the sketch
# sketch and the pad have to be selected altogether
# (Ctrl to select the second object)
import FreeCAD, FreeCADGui
def padOfSketch(sketch) :
# get pad of selected Sketch if exist
for obj in FreeCAD.ActiveDocument.Objects :
if obj.TypeId == 'PartDesign::Pad' :
if obj.Profile[0] == sketch :
return obj
return None
# Main proceddure
def main():
# get selected pad
if len(FreeCADGui.Selection.getSelection())!= 2 :
print('Select one sketch and one pad')
return
# have a look to first selected object
sel = FreeCADGui.Selection.getSelection()[0]
if sel.TypeId == 'Sketcher::SketchObject' :
selSketch = sel
sketchOnPad = False # if True Sketch will be on the pad else under the pad
elif sel.TypeId == 'PartDesign::Pad' :
selPad = sel
sketchOnPad = True # Sketch will be under the pad
else :
print('- Select one sketch and one pad.')
# have a look to second selected object
sel = FreeCADGui.Selection.getSelection()[1]
selSketch = sel
selPad = sel
else :
print('-- Select one sketch and one pad')
# get pad properties
selectedPadName = selPad.Name
selectedPadLength = selPad.Length
selectedPadSketch = selPad.Profile[0]
selectedPadSketchName = selectedPadSketch.Name
padSelectedSketch = padOfSketch(selSketch)
# support and MapMode must be the same
selSketch.Support = selectedPadSketch.Support
selSketch.MapMode = selectedPadSketch.MapMode
if sketchOnPad :
expression = selectedPadName + '.Reversed == False ? ' + selectedPadSketchName \
+ '.AttachmentOffset.Base.z + ' + selectedPadName + '.Length : ' + selectedPadSketchName + '.AttachmentOffset.Base.z'
padSelectedSketch.Reversed = False
else :
expression = selectedPadName + '.Reversed == True ? ' + selectedPadSketchName \
padSelectedSketch.Reversed = True
selSketch.setExpression('.AttachmentOffset.Base.z', expression )
if __name__ == '__main__':
main()
