PD Chamfer is SegFaulting Freecad
Shalmeneser
Re: PD Chamfer is SegFaulting Freecad
Post by Shalmeneser »
Method :
1) Select any edge
2) Chamfer tool
3) Change dimension
4) Add your desired edge
5) Suppress the 1st edge
Like @papyblaise, I would do the fillets inside the sketch : no more TNP.
You can also do 1/2 of the form then mirror it.
And please provide MWE = minimal working example
GeneFC
Post by GeneFC »
A really useful improvement to FreeCAD would be a change to "Sorry Dave, I can't do that" when opening an operation that contains an unusable default condition. The user would be prompted to make adjustments instead of dealing with a crash.
The latest approach of "open the operation before selecting the target element" is a kludge fix at best.
This may not be easy, but it would be a lot more worthwhile than diddling with the arrangement of icons and toolbars. :mrgreen:
Gene
TheMarkster
Post by TheMarkster »
GeneFC wrote: Sat Apr 01, 2023 2:52 pm A really useful improvement to FreeCAD would be a change to "Sorry Dave, I can't do that" when opening an operation that contains an unusable default condition. The user would be prompted to make adjustments instead of dealing with a crash.
Gene
If the crash is happening during the call to the OCCT function, then you need to be able to detect you will get a crash before making the call, which would be very challenging to do. If the call to OCCT was done from within a new subprocess, then perhaps FreeCAD could recover from the crash, but I don't know if even that would work. At best, it would slow things down considerably, I would think, not to mention greatly complicating the code.
user1234
Post by user1234 »
I tried the file from @papyblaise and get no crash. The download from dropbox does not work. As other said, a MWE would be good, also which edge does not work (screenshot), because the model have 90 edges.
OS: Debian GNU/Linux 11 (bullseye) (X-Cinnamon/lightdm-xsession)
Version: 0.21.0.32656 (Git)
Hash: fa3ee342804f3658088b121b10a0ae0b981c49fa
Python 3.9.2, Qt 5.15.2, Coin 4.0.0, Vtk 9.0.1, OCC 7.7.1
  * QuickMeasure 2022.10.28
  * Assembly4 0.12.6
  * CurvedShapes 1.0.4
  * Curves 0.6.8
Greetings
user1234
leoheck
Post by leoheck »
papyblaise wrote: Sat Apr 01, 2023 7:24 am I don't have a crystal ball to see which edge is the problem :!:
I would recommend you to look inside the file then, you can use Freecad to open it.
leoheck
Post by leoheck »
Shalmeneser wrote: Sat Apr 01, 2023 10:04 am Method :
1) Select any edge
2) Chamfer tool
3) Change dimension
Thanks, I am not looking for a workaround.
I am reporting here Freecad is crashing because it is failing to do something instead of telling the user it is not possible.
You can use the file I shared, if it is not good enough you could try to replicate the issue from your side.
leoheck
Post by leoheck »
@TheMarkster the same crash does not affect the PD Fillet tool, if I am no mistaken. But I will have to double check. Does this give a hint on where/why this happens?
leoheck wrote: Sat Apr 01, 2023 12:44 am This is good. Actually, I realized this is already the New Chamfer tool, then this Seg Fault is a new bug introduced, for sure.
not for sure unless you have tested on an earlier version and it worked...
leoheck
Post by leoheck »
adrianinsaval wrote: Sat Apr 01, 2023 10:43 pm not for sure unless you have tested on an earlier version and it worked...
Indeed, but I don't have a crash like that (with chamfers) since a long time ago. More than a year, maybe.
I can confirm the crash happens, please make an issue on github, attach the file and add a screenshot showing which edge triggers the issues.
