Part->sweep of a Draft->Circle along Part->Helix gives weird results
Lupin
Post by Lupin »
I want to model the handrail of a helical staircase. When I sweep a circle along a helix in FreeCAD, the result is very inconsistent and for example depends on the diameter of the swept circle. While in my example I sweep a simple Draft->Circle along a helix, the exact same is happening when I draw the circle in a sketch (I guess internally those two things are same in FreeCAD).
Here's the result of sweeping three circles (30mm, 75mm, 150mm radius resp.) along the same helix (with the sweep moved in z direction).
Changing any of the sweep properties (Solid, Frenet, Transistion) does not change the outcome.
broken_helical_sweep.FCStd
(19.14 KiB) Downloaded 18 times
openBrain
Re: Part->sweep of a Draft->Circle along Part->Helix gives weird results
Post by openBrain »
This has been discussed several times already. You should find with a search on the forum.;)
Bildschirm­foto 2023-03-30 um 19.46.36.png (21.98 KiB) Viewed 627 times
Divide the helix into shorter segments:
fixed_helical_sweep_cb.FCStd
(33.89 KiB) Downloaded 16 times
user1234
Post by user1234 »
Finally, it seems to be solved in OCCT7.7.1 . Would be good, if someone can confirm it.
OS: Debian GNU/Linux 11 (bullseye) (X-Cinnamon/lightdm-xsession)
Version: 0.21.0.32637 (Git)
Hash: 7fa7cb7f0b222864be7416c683166876eab190bc
Python 3.9.2, Qt 5.15.2, Coin 4.0.0, Vtk 9.0.1, OCC 7.7.1
  * QuickMeasure 2022.10.28
  * Assembly4 0.12.6
  * CurvedShapes 1.0.4
  * Curves 0.6.8
Greetings
user1234
Wasn't this solved in 7.6.something already? OP didn't post full version info unfortunately :roll:
Lupin
Post by Lupin »
openBrain wrote: Thu Mar 30, 2023 5:35 pm This has been discussed several times already. You should find with a search on the forum.;)
I did search the forum and the closest thing I found was this:
viewtopic.php?t=57984
But changing the tesselation settings, as described in that thread, didn't change anything either (btw. I change those settings sometimes anyway for mesh exports for 3D prints).
adrianinsaval wrote: Thu Mar 30, 2023 5:54 pm Wasn't this solved in 7.6.something already? OP didn't post full version info unfortunately :roll:
I always think about that, but then forget :roll:
Version: 0.20.1.29410 (Git)
Branch: releases/FreeCAD-0-20
Locale: German/Austria (de_AT)
  * Assembly4 0.12.5
  * fasteners 0.4.54
  * kicadStepUpMod 10.17.1
  * lattice2 1.0.0
  * Manipulator 1.5.0
  * Part-o-magic 1.0.0
  * PathDressupDogbone.py.mod
  * startup_macros
  * TabBar
  * workfeature
chrisb wrote: Thu Mar 30, 2023 5:47 pm Divide the helix into shorter segments:
That seems to be the solution. Thank you! The annoying thing: I played with the segment length value while trying to get the swept helix to be rendered correctly, but I must have had an unfortunate combination of values, because it wasn't fixed by that at the time and dismissed that as an option. :(
user1234
Post by user1234 »
This was also what i thought, but sometimes in sweeps in PartWB had still this issue. When i look on the example file, then yet (pretty late) i get the idea, that it have something to do with the section area to length ratio.
Greetings
user1234
openBrain
Post by openBrain »
Lupin wrote: Thu Mar 30, 2023 6:13 pm I did search the forum and the closest thing I found was this:
This thread and others linked there should be helpful : viewtopic.php?t=64333
Not in 7.6.3
OS: macOS 10.16
Version: 0.21.0.32532 (Git)
Hash: 20e44eba50e1365b9e7bb9c5c244afe96a627a28
Locale: C/Default (C)
