Chewed out section... can you help?
johnstonf
Post by johnstonf »
OS: macOS 10.16
Version: 0.20.2.29603 (Git)
Locale: C/Default (C)
I have a test model, and it has two sections, and the taller section has a pocket to create a track for a thin lid to slide in on. It works and prints, but has this notch chewed out near where the pocket exits from the outer wall.
I've attached my doc and some photos (hard to describe).
Just curious how i can fix it, what i did wrong.
/f
Screen Shot 2023-03-30 at 11.42.49 AM.png (160.3 KiB) Viewed 584 times
Screen Shot 2023-03-30 at 11.43.03 AM.png (103.74 KiB) Viewed 584 times
Screen Shot 2023-03-30 at 11.43.20 AM.png (316.92 KiB) Viewed 584 times
Screen Shot 2023-03-30 at 11.42.34 AM.png (91.9 KiB) Viewed 584 times
AAA-QQQ-024c.FCStd
(97.5 KiB) Downloaded 13 times
Re: Chewed out section... can you help?
That doesn't look like a modeling but rather like a printing issue. With an FDM printer you cannot print such faces in the void. Your slicer may have added automatically some support structure which has to be removed.
johnstonf
Post by johnstonf »
As the third image I attached, 3rd photo, it is clearly in the modeling. That's a photo of a screen right from freecad...
My slicer would put a support in there if it can't handle it.
/f
johnstonf
Post by johnstonf »
In fact, there is about a 1mm slice that it DID print over the slit.
I attached another angle photo... hope it shows better...
Screen Shot 2023-03-30 at 1.22.13 PM.png (209.09 KiB) Viewed 508 times
Shalmeneser
Post by Shalmeneser »
Show hidden items
-> LidSlotExtrude
That's exactly what I see in your model:
Bildschirm­foto 2023-03-30 um 19.51.26.png (10.98 KiB) Viewed 481 times
johnstonf
Post by johnstonf »
EXACTLY,
I don't want that hollowed out piece, just the slit, and filled in up flush to the top level.
I can't figure out where that is coming from (Yup, newby question, I'm sure LoL.)
Thanks!
edwilliams16
Post by edwilliams16 »
johnstonf wrote: Thu Mar 30, 2023 7:27 pm
@Shalmeneser told you the problem. You have a superfluous pocket operation that you managed to make hidden. Here I unhid it (right click menu) and zeroed the pocket Length2, so it does nothing.
AAA-QQQ-024c_EW.FCStd
(76.31 KiB) Downloaded 5 times
user1234
Post by user1234 »
Shalmeneser wrote: Thu Mar 30, 2023 5:40 pm Show hidden items
-> LidSlotExtrude
Congrats to the fast find, never saw a hidden (except defaults) object in FreeCAD ever. How did you found that so fast? You Did you always search hidden objects? I mean, i see it in the dependency graph, but never came to the idea to search hidden objects.
Greetings
user1234
johnstonf
Post by johnstonf »
Holy moly, thanks... I didn't even know about hiding, HONESTLY!... NOT sure how i accomplished that... Thanks!
(A new thing learned!)
/f
