[Feature request] AutoUpdate dimensions on geometry change
Fantoche
Post by Fantoche »
Make the dimensions linked to the geomtry they reference, so when the geomtry (if referenced points) changes , the dimensions update accordingly
for exemple, lets say I have a dimension renferencing tow points of an ArchWall object, if I resize the length of the wall the dimension should resizes accordingly.
Roy_043
Re: [Feature request] AutoUpdate dimensions on geometry change
Post by Roy_043 »
If you select an edge instead of points the dimension will be parametric.
Fantoche
Post by Fantoche »
Roy_043 wrote: Thu Mar 30, 2023 3:34 pm If you select an edge instead of points the dimension will be parametric.
Cool what about the distance between two walls ? is it possible to have a parametric dimension between them, especially if they are parallel ?
Roy_043
Post by Roy_043 »
Currently this is not handled automatically. Through expressions you can manually make such a dimension parametric, but this is cumbersome. See attached file.
param_point_to_point_draft_dim.FCStd
(13.78 KiB) Downloaded 34 times
yorik
Post by yorik »
One thing could be cool, like in the sketcher: Change the icon of the dimension in the tree view if it is parametric
