Can't fuse in 1 object
Fussion Issue
Want to make it in object. To send it to path.
FreeCAD 20.2 yesterday I made similar operation with other shape, with no issue to produce path but idk what issue is here
- Try_2.jpg (233.57 KiB) Viewed 500 times
- Eye_hole_error.FCStd
- (270.42 KiB) Downloaded 4 times
- Try_1.jpg (249.27 KiB) Viewed 500 times
Re: Can't fuse in 1 object
Part_CheckGeometry shows problems with the chamfer that will appear later in the fusion operation.
It's not show any error for me
- Try_3.jpg (233.02 KiB) Viewed 473 times
Select Chamfer line in the construction tree (not in the 3D view).
The chamfer show issues on CheckGeometry with BOPcheck. Do you have the paths as sketches? I guess there are transitions that aren't really tangent but should be.
If it's Model tab where "Labels & Atributes" it gave me same result.
I use SVG from corel, then aply Extrude on path, and then use chamfer on that extrude
Can you provide the svg file ?
Sure here it is
- Frame_for_freecad.svg
- (3.18 KiB) Downloaded 2 times
If construction points in your svg file become 'smooth', then there are less problems.
I made new from scratch and made all nodes smooth. but now I can't even make champfers
Edit: currently trying Fix nodes in Inkscape. maybe it have better algorithms
- Eye_hole_smooth_smooth.svg
- (3.09 KiB) Downloaded 2 times
