Print ant Print preview scr*ed up
BartR
Post by BartR »
When I create a print preview, I get this out of center (see attachment)
Moreover: when printed in PDF (100% scale) the final design is bigger than the one really sketched.
I can't get the correct scale
No mater paper orientation or else.
  * 3D_Printing_Tools
  * A2plus 0.4.60k
  * ArchTextures
  * Assembly4 0.12.6
  * CADExchanger
  * CubeMenu
  * CurvedShapes 1.0.4
  * Curves 0.6.8
  * ExplodedAssembly
  * fasteners 0.4.56
  * fcgear
  * freecad.gears 1.0.0
  * InventorLoader 1.3.0
  * kicadStepUpMod 10.17.6
  * lattice2 1.0.0
  * MeshRemodel 1.8919.0
  * pcb
  * PieMenu 1.2.7
  * QuickMeasure 2022.10.28
  * Render 2023.2.2
  * sheetmetal 0.2.63
  * ThreadProfile 1.84.0
  * WebTools
______________
Bart R.
Re: Print ant Print preview scr*ed up
The Tools->SaveImage function basically makes a screenshot which dependes on the zoom level. For a technical drawing use the TechDraw workbench.
BartR
Post by BartR »
chrisb wrote: Thu Mar 30, 2023 10:02 am The Tools->SaveImage function basically makes a screenshot which dependes on the zoom level. For a technical drawing use the TechDraw workbench.
I used File > Export PDF
And it's not 1:1 .. even putting Scale 100% etc ...
I need to print on paper the object 1:1
______________
Bart R.
drmacro
Post by drmacro »
Make sure your printer has "scale", "fit", or whatever it calls it turned off, or you'll never get it a 1:1 print.
BartR
Post by BartR »
drmacro wrote: Thu Mar 30, 2023 11:34 am Make sure your printer has "scale", "fit", or whatever it calls it turned off, or you'll never get it a 1:1 print.
yes I was making sur thies.
HOwever with TechDraw the prints are ok: 1:1
With the PDF not at all
______________
Bart R.
I guess you use the Print PDF function of the 3D view. How do you expect to get an object in the PDF that has the exact same size as you modelled it? This just isn't possible because the size of the object of the embedded image depends on the zoom level. This means if you create 3 PDFs of the same object with 3 different zoom levels then the results are all different.
BartR
Post by BartR »
wmayer wrote: Thu Mar 30, 2023 12:54 pm
I explained how I export in PDF. Since it's File > Export PDF
So I must have the 1:1 if I chose for it as I did.
______________
Bart R.
BartR wrote: Thu Mar 30, 2023 2:17 pm So I must have the 1:1 if I chose for it as I did.
No. That's a screenshot wrapped in a pdf file. Thus it depends on what and how you show it in 3D view.
BartR
Post by BartR »
chrisb wrote: Thu Mar 30, 2023 4:15 pm
ok, so the only one way (that's working) is the one you suggested by the use of TechDraw.
______________
Bart R.
GeneFC
Post by GeneFC »
BartR wrote: Thu Mar 30, 2023 2:17 pm I explained how I export in PDF. Since it's File > Export PDF
How are you trying to select 1:1?
I do not see any such option for File > Export PDF.
(As others have said, TechDraw is the proper method to get correctly scaled printouts.)
Gene
