Loft Problem [SOLVED]
Laurie Hartley
Re: Loft Problem [SOLVED]
Post by Laurie Hartley »
papyblaise wrote: Fri Mar 31, 2023 7:44 am I took your file to modify the flow and especially the shape of the duckbill using only arcs of circles to allow the subsequent welding radius
Thank you Papyblaise that looks terrific. I will examine your file tomorrow.
Laurie Hartley
Laurie Hartley wrote: Fri Mar 31, 2023 10:41 am
Bance wrote: Fri Mar 31, 2023 7:01 am It's in my file, you must use the multitransform tool since it is not possible to pattern a pattern otherwise.
Use two mirror operations with different axis of symmetry.
Double click on the multitransform in the treeview to open the edit dialogue.
Thanks once again Bance - I will have another attempt tomorrow.
After a couple of hours trying to figure this out I almost gave up but thanks to our friend at Joko Engineering
https://youtu.be/g487DTBOdjU
I realise where I was going wrong - I was trying to use the mirror tool after I had created the Multitransform :oops:
For the benefit of anyone who has similar difficulties as how this works here are the steps I took:-
1. Selected the pad and additive loft using the control key
2. Selected the Multitransform icon
3. A window with two panes opened above which was a green message stating the transformation had succeeded
4. I right clicked in the lower of the two windows and chose add mirrored transformation
5. Chose as the plane "vertical sketch axis" then "OK"
6. Right clicked on the lower pane again
7. Chose as the plane "horizontal sketch axis" then "OK"
Very simple really - that's probably why I struggled with it - complication is my forte :lol:
Thank you Bance, Thomas and Papyblaise for helping me. I appreciate it.
Bance
Post by Bance »
Laurie Hartley wrote: Sat Apr 01, 2023 5:11 am Very simple really
And it's all written up in the wiki ;)
