[not bug] GetSelectionEx: selection order information is incomplete
DeepSOIC
Post by DeepSOIC »
1. make two Part Cubes, move them apart
2. select edges in this order:
3.
>>> [(so.Object.Name, so.SubElementNames) for so in Gui.Selection.getSelectionEx()]
[('Box001', ('Edge12', 'Edge10')), ('Box', ('Edge12', 'Edge10'))]
As it should be clear from the console dump, it is impossible to figure out the true order in which the edges have been selected, as both Box001's edges have been grouped into one selection object.
This bug was causing me some trouble when invoking attachment with preselection.
Version: 0.21.0.32457 (Git)
Hash: 85216bd12730bbc4c3cbf8f0bc50416ab1556cbb
Python 3.10.9, Qt 5.15.8, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Locale: English/Germany (en_DE)
  * CurvesWB 0.4.4
  * DeepConsole
  * fir_design
  * Lattice2 1.0.0
  * Part-o-magic 1.1.0
  * TabBar
  * _disabled
openBrain
Re: GetSelectionEx: selection order information is incomplete
Post by openBrain »
I can confirm but it doesn't qualify as a bug.
It is ... well .. as intended.
You can get what you're expecting (I guess) with :
[(so.Object.Name, so.SubElementNames) for so in Gui.Selection.getCompleteSelection()]
DeepSOIC
Post by DeepSOIC »
okay, somehow i didn't know that, thanks!
freedman
Re: [not bug] GetSelectionEx: selection order information is incomplete
Post by freedman »
I remember an issue I had; as I clicked on objects using getSelectionEx it worked as expected except for one thing, it would not return anything for a click on a Body in the tree. It was strange because every other clicked item returned something. I will post some code if there is some question.
Thanks
I think I used "getSelectionEx()[0]
Edit; Changed selection type
